Old 09-06-2014, 10:21 PM   #1
Kryton
Kryton's Avatar
Default AU I6 cylinder heads - all the same?
Quick question:
Are all AU I6 cylinder heads the same from Series 1-3 and LPG to Petrol (Excluding all VCT heads) or are there differences with valves etc?
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2014, 10:45 PM   #2
The Monty
Just slidin'
The Monty's Avatar
Default Re: AU I6 cylinder heads - all the same?
I might end up being corrected, but I believe the AU HP had a slightly differing head in some way too.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 11-06-2014, 12:56 PM   #3
Kryton
Kryton's Avatar
I was mainly looking at standard heads.
ie: will a S3 head fit onto an S1, is petrol the same as LPG?
Old 11-06-2014, 08:54 PM   #4
Bossxr8
Peter Car
Bossxr8's Avatar
LPG heads had hardened valve seats.
Old 14-06-2014, 12:06 PM   #5
shayne93
66 Mustang
shayne93's Avatar
The HP (Factory red rocker cover) head has a different camshaft and has a 'T' for Tickford cast into the front.
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2014, 01:58 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I'm 90% sure the LPG heads were exactly the same as the petrol heads
My AUII is made before the EGAS option was available, and is a Factory Tickford Dual-Fuel
It's my understanding that right throughout the AU production run they just plucked an ordinary AU when it rolled off the production line and then Tickford did the Vialle gas fitout. This was an option available right throughout the AU range.
My understanding is that the Green-Top E-gas motors had no differences to the petrol motors except no holes for the petrol injectors. And i'm pretty sure they both had the same 9.6:1 compression ratio.
Old 17-06-2014, 05:09 PM   #7
Bossxr8
Peter Car
Bossxr8's Avatar
There was definitely a different head on E Gas motors, I specifically remember that when they were fitted on the assembly line. They had harder valve seats and possibly better exhaust valves to handle more heat.
Old 02-07-2014, 04:55 AM   #8
Stav
Smile
Stav's Avatar
The au heads were pretty much the same spec but the hp had a bigger cam to gain 10 odd kilowatts over standard. Between au1 2 and 3 no differences but there are definately casting differences which made the ports flow better . If you go to a wreckers and look into the ports you will see the differences in intake ports . Lpg ran harder valve seats from memory
