Old 19-06-2014, 10:37 AM   #1
wis33Y88
Default Au xr8 220 running rough at top end of revs
Hello everyone I've got an au xr8 ute 220 hand built in the last month it has been running rough around the 4000rpm like it's looking for fuel or not getting enough and if I put my foot down to quick it does the same thing?? Any ideas??
wis33Y88 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2014, 12:44 PM   #2
BOTTLEDUP
Default Re: Au xr8 220 running rough at top end of revs
Broken valve spring?
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2014, 10:00 PM   #3
Jarry
Going with the X-Flow
Jarry's Avatar
fuel pump?
Jarry is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2014, 11:13 PM   #4
BEN XT
BEN XT's Avatar
Leads maybe?
BEN XT is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2014, 09:02 AM   #5
wis33Y88
Leads plugs and fuel pump have been replaced within the last 5000km
Old 20-06-2014, 09:13 AM   #6
Jarry
Jarry's Avatar
blocked cat?
Old 20-06-2014, 10:05 AM   #7
wis33Y88
Does anyone know the valve specs on the yella terra ?
I've looked at heaps but just want to double check their the 1.72
Don't want to order the wrong ones
Old 20-06-2014, 07:12 PM   #8
b2tf
not here much anymore
b2tf's Avatar
Pop a rocker cover, if the rocker has the Yella Terra logo on it they will be 1.72's. If they dont have anything written on them they will be Crane 1.6's. I would near bet being a series 3 it will have YT's on it, by the way it's not a 220 motor. Utes only got the 200 motor.
2024 F150 XLT
Old 20-06-2014, 11:15 PM   #9
wis33Y88
I took the rocker off and their yellas,
And she's a series 2 pursuit and the tb is also 70mm and the yellas so we rang fpv in Melbourne last week and gave them the vin number,
they called back today and they have confirmed its a 220, they slapped a few of them in some utes when they had leftover rebel motors.
Old 21-06-2014, 10:43 AM   #10
mik
mik's Avatar
Coil/s ?
Old 21-06-2014, 07:20 PM   #11
b2tf
b2tf's Avatar
Yep. No worries.
2024 F150 XLT
Old 23-06-2014, 11:20 AM   #12
STINKY NINJA
Does it have an engine oil cooler behind the grill with the lines running to the oil filter block?
Rebels didnt get a special 220 motor ,it was the same 220 all the later series 2 and 3 xr8 got,i think ford just make stuff up sometimes,i dont doubt it could be a 220 motor but that ford story is hell dodgy lol...
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2014, 11:24 AM   #13
wis33Y88
Yes it has a oil cooler with lines going to the oil filter
Old 23-06-2014, 11:26 AM   #14
STINKY NINJA
Does the engine number match the vin?
If it does i think i learnt something today,i never knew utes could have the 220 motor!
Old 23-06-2014, 11:30 AM   #15
wis33Y88
Yes the vin and engine numbers match it's my 4th au but my 3rd v8 n I was the same until I got this one it runs so much better then the last 2 but now I have tis problem is the only reason I've worked out its a 220 from talking to ford in Melbourne
Old 23-06-2014, 12:06 PM   #16
STINKY NINJA
Did you check for broken springs?
Old 23-06-2014, 12:10 PM   #17
wis33Y88
I'm pulling the right side off today checked the left side I the other day just because it was easy to get to just a pain taking in intake manifold off but it has to be don't
Old 23-06-2014, 11:29 PM   #18
wis33Y88
Checked all springs today and they are all fine I'm starting to think its coils
Old 03-07-2014, 12:16 PM   #19
dwnsnow
maybe your harmonic balancer my series 3 220 was doing a simular thing changed it out with a new powerbond unit cured the problem
dwnsnow is offline   Reply With Quote Multi-Quote with this Post
