Old 07-08-2014, 07:53 PM   #1
Poorboy_racer
Poorboy_racer's Avatar
Default Hypothetical question
A recent discussion:
You have a car that runs 16 second standing quarter miles.
You get another identical car that also runs 16 second standing quarters.
You weld the front of one car to the back of the other, forgetting logistics like cooling for the second car etc, you link the accelerators and gear shifts. Lock the steering of the second car.
Would the combination of cars be slower than 16 seconds over the quarter?
Faster over the quarter?
Or the same?
1 Friend says faster as first car cuts the air for the second.
Other says depends on power to weight of cars. If the power to weight is low the two engines won’t make up for the increased inertia getting it off the line. With a high power to weight (should run better than a 16 in the first place) the engine power would more than make up for the increased weight/inertia.
Me? I think leave it to Mythbusters.
Poorboy_racer is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 07:56 PM   #2
39ClevoUte
39ClevoUte's Avatar
Default Re: Hypothetical question
Friend 1
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 08:35 PM   #3
Charliewool
Bolt Nerd
Charliewool's Avatar
But............. WILL A PLANE take off if it was on a giant conveyor belt going backwards at a speed realtive to the planes thrust?
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 09:01 PM   #4
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
no change. F=ma you've doubled the force but you've doubled the mass too. simplistically
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 09:45 PM   #5
CoupeKing
3 2 1...sick of hearing that, just press the button when the rest of the set least expects it.
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 11:08 PM   #6
ford man xf
Depends if the flux capacitor is in the first or the second car?
It's pretty amusing though, considering the XR8 next year will be reborn with the same spec engine as the FG GT, could you imagine being a HSV owner forking out all that money on a brand new GTS, then pulling up to the lights next to a FH XR8 and then sitting side by side all the way to 100 and beyond
Even more embarrasing would be the lower spec variants of the VF in HSV's stable getting whopped by a factory XR8.
ford man xf is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 11:17 PM   #7
CyberWasp
CyberWasp's Avatar
Now you made my brain hurt.....I am going to go and lay down.
2004 Mercury Silver Falcon XR6T - 5 Speed
2017 Platinum White Mustang GT - 6 Speed
2022 Blue Thai-Special for Daily Duties - Auto
CyberWasp is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2014, 11:18 PM   #8
Crazy Dazz
Correct, its called bump-drafting.
You don't even need to weld them together.
First car will be faster as the 2nd car slipstreaming will reduce its drag.
That said, over a quarter the difference would be negligible, as aerodynamics play only a minor part in such races.
Crazy Dazz
Kicking Hippies in the Balls since 1966
Old 08-08-2014, 09:08 AM   #9
Peter B - CV8
Wouldn't it be the other way around ?? ie the leading car (no1) is copping all the frontal drag - therefore allowing the car behind (no2) to have a slightly increased speed, until it overtakes at which point the roles are reversed.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2014, 10:45 AM   #10
EgoFG
If the are the same then it could theoretically be faster.
Double the power, double the grip
Double the weight, double the aero drag on the sides, but the front and rear aero drag are not doubled.
There will be less total aero drag.
But if the cars were not identical ... and had different gear change points .... now that would be fun.
EgoFG is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2014, 11:52 AM   #11
Poorboy_racer
So if one car were faster than the other which car goes in front?
Faster one or slower one?
