Old 21-10-2014, 08:04 PM   #1
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Right rear noise, split exhaust hanger, related?
Hi all, how are we! My AU has just started to develop a tonk, tonk, tonk sound right rear, going right around roundabouts. Also noticed the last rear exhaust hanger rubber holder has got a split in it, just wondering if related. Have you ever heard that sound in a AU before. Thanks for any input!
cheers, Maka
Old 22-10-2014, 08:54 AM   #2
Maka
Maka's Avatar
Default Re: Right rear noise, split exhaust hanger, related?
Just tested it while out for a drive & its not the exhaust. That leaves a couple of other things to check now. Very interesting!
cheers, Maka
Old 22-10-2014, 06:25 PM   #3
Maka
Maka's Avatar
Diff or handbrake i think, needs closer inspection. Inspected the shocks they are good, springs probably a bit old now though. I should find the issue soon.
cheers, Maka
Old 22-10-2014, 06:40 PM   #4
tut0r
tut0r's Avatar
Hey mate I think I have the same issue, got my diff replaced and handbrake adjusted...suffice to say the handbrake is useless again! Typical falcon! But I have that noise, I only heard it when braking under 30km/h but it has become more prominent now, I'd suspect handbrake first as my diff is brand new besides the housing and yoke!
Let us know how you go I haven't had a chance to get it sorted it.
Ride
2007 Ripcurl BF Xr6 Ute
Mods to Date
Ceramic Coated Pacemaker 4495s
2.5" Dual Venom exhaust,
Bluepower CAI
Eaton True Trac with 3.9s
20% Underdrive
EcoLpi Motor
RWKW: 200.0
Nm: 394
Mods to Follow
Supercharger
T56 Conversion TR6060
tut0r is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2014, 07:56 AM   #5
Maka
Maka's Avatar
Hi Tutor, thanks for the reply! Yeah no worries, i'll let you know. Empty boot atm
cheers, Maka
Old 23-10-2014, 08:40 AM   #6
Maka
Maka's Avatar
Ha ha, no noise this morning doh, so its intermittent. Yesterday i dismantled some stuff to have a look see & i securely fitted the rrh shock body plastic protective sheath which was pretty loose fitting & the handbrake cable is zipped tied near were the cable goes into the brake hub but rubbing against the diff housing, so its floating & moving a bit.
The sound is bit hollow sounding though so its a little clue i think, i'll keep ya posted!
cheers, Maka
Old 24-10-2014, 09:29 AM   #7
Maka
Maka's Avatar
Its fixed for now i reckon, spare is tightened down properly, boot emptied of not needed tools & stuff, rrh shock is fine now, exhaust hanger rubber holder fine now, handbrake cable routing all good now.
The noise was serious at first & getting worse but all good now.
cheers, Maka
