12-08-2015, 03:36 PM | #1 | ||
does any one have a pic/drawing of where all the vacume lines go on a series 3 xr8?
cheers |
14-08-2015, 08:13 AM | #2 | ||
Chairman & Administrator
Which vacuum lines? The HVAC ones, underbonnet ones?
Cheers Russ
Observatio Facta Rotae
14-08-2015, 09:09 AM | #3 | ||
yeah all the small ones that come from intake and also the stuff for the charcoal cannister.
cheers |
14-08-2015, 04:32 PM | #4 | ||
Try this ....
14-08-2015, 04:56 PM | #5 | ||
cheers its more the engine side i need as i brought a xls ute rolling shell and put a 220kw v8 in it just trying to get it all plumbed in.
cheers |
15-08-2015, 07:58 AM | #6 | ||
You asked for the carbon canister which is why I used that one - can you try to be specific as we can't read minds. Not a lot of diagrams but here are a couple are a couple I found.
Russ
15-08-2015, 08:26 AM | #7 | ||
Next upgraded Mk1 Leopard
I knew you would say that
UK
15-08-2015, 06:32 PM | #8 | ||
sorry where does the vac line go that come from the fire wall? and what connects to the 2 outlets at the front and rear of the upper intake?
cheers |
