Old 26-01-2016, 05:05 PM   #1
Night_EF
Default Series 1 Forte Questions
Hi all,
My Forte is still hovering about 106,000kms so internally it's still good but the exterior I want to just clean up a little. Some things are small and I guess most people wouldn't bother with it, but it gives me some ocd lol
1- There's some clear coat peel on the boot and fade on the roof I want to clean up, and some dents around the rear left wheel arch I want sorted out, who should I see for this? ( or google )
2- The boot is missing the gas struts that holds it up when opened, I bought a pair on ebay, are they straight forward to install? or should I bring them to a workshop.
3- The rear spoiler: the left side can't be screwed down, what should I do to hold it down? I thought about finding a spoiler at a wreckers or something and bolting that on but if there's a way I can hold it down I'll give it a try.
4- One thing I want improved are the brakes, they are not the worst but would anyone know an estimate on how much it would cost to upgrade them? ( Sydney area )
Thanks
Night_EF is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2016, 05:54 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Cool Re: Series 1 Forte Questions
Originally Posted by Night_EF View Post
Hi all,
Thanks
No 2 is a straight easy install. Mind you head
No 3 Take the whole spoiler off and check the connections
No 4 Check the AU brake post, it has every thing you need.
And Welcome
UK
Old 26-01-2016, 06:02 PM   #3
Night_EF
Default Re: Series 1 Forte Questions
thanks, glad it's a simple install. As for the spoiler, the holes where the screws go in can't be used on the left side, it's pretty bad lol
I seen the AU 2 and 3 series brake thread, I'll look for one applicable to me
Old 26-01-2016, 06:05 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
Question Re: Series 1 Forte Questions
You need the Series 1 bits. Pick and pay less @ Blacktown have heaps of AU II/III you can get what you need. What colour spolier?
UK
Old 26-01-2016, 07:18 PM   #5
Night_EF
Blacktown? cheers not far from me, and it's (B5) Sparkling Burgundy
Old 26-01-2016, 07:27 PM   #6
Before you head out there look them up on the interweb first as they have all there cars up and lists of removed parts. The $2 entry fee is nothing, but the drive out there with tools to find the part you are after has been taken already is an irritation
Old 26-01-2016, 07:54 PM   #7
Uncle_Ken
Uncle_Ken's Avatar
True that, you do need the gear to get what you need off. There are a few Burgundy AUs but U can't remember the nic of the paint. FordPro @ 94 Victoria St, Smithfield, Sydney have the items as well but will remove/get the bits you want.
UK
Old 01-02-2016, 01:13 PM   #8
Brendo71
Brendo71's Avatar
in regards to your spoiler screw problem, you could try filling up the dodgy hole/s with epoxy putty. Once dry you simply drill a small pilot hole and let the screw do the rest. Saves buying a whole new spoiler!
Brendo71 is offline   Reply With Quote Multi-Quote with this Post
