Old 31-01-2016, 12:29 AM   #1
Shonky.
Shonky.'s Avatar
Default Help with KJ Laser 1.8 DOHC camshaft timing
I just did the water pump on our KJ 1.8 twin cam
Pump is good, but I suspect when I did the timing belt I got it wrong, as it runs like a hairy goat now
I had to guess the timing marks as had no workshop manual
Devo'd that I have to pull it down again
Can you guys tell me what the orientation of the two cam sprockets should be?
I've got the crankshaft one sorted, as it's easy to see the top dead centre mark
There seems to be at least 3 three marks on each cam sprocket and both have an "E" and an "I", as well as a "Z"
I always thought they just had an e for exhaust and an I for inlet which had to be lined up in the centre
Thanks so much
Shonky. is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2016, 08:29 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: Help with KJ Laser 1.8 DOHC camshaft timing
I'll email you the relevant section.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2016, 09:33 AM   #3
Shonky.
Shonky.'s Avatar
received, thank you
I hunted round the internet trying to find info, and as per usual all I had to do was ask on here!
thanks so much Russ
