Old 30-04-2016, 06:56 PM   #1
joseph23
Default headlight and blinker issue
Hi
I noticed tonight that with my headlights on my right blinker stayed solidly lit and didnt flash at all, was solid on the dash to.
But once the headlights were off it worked perfectly fine. I also noticed that when the car locked and unlocked as the blinkers flashed so did the parker globes flashed also along with the tail and number plate lights.
Is a AU Series 2 sedan.
Any suggestions?
joseph23 is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2016, 09:11 PM   #2
XR8235
Default Re: headlight and blinker issue
Hey mate
Check your trailer plug wiring
XR8235 is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2016, 09:17 PM   #3
joseph23
hi
thanks for the reply. I riggled a wire behind the right headlight and it seemed to fix it momenterily. Would a earth or grounding problem cause this?
Old 30-04-2016, 10:55 PM   #4
XR8235
Yes. Possibly, but still check your trailer plug wiring. If any thing goes wrong like this always check anything fitted after it was built, even if it was dealer fitted
Old 01-05-2016, 10:57 PM   #5
IH8HSV
XR6T 400kw(well one day!)
IH8HSV's Avatar
Originally Posted by joseph23 View Post
Hi
Any suggestions?
You have a short between the indicator and the park lights.
When your park lights are on, its supplying constant power to the indicator light - therefore why it no longer blinks, and stays constantly on.
Your park lights are on the same circuit as your dash lights and number plate lights - so when you open / close the door to activate the indicators - these lights also light up.
Most common spot is in the rear light holders. Completely disconnect each tail light assembly seperatly and see if the problem goes away. If it does then you know what side is causing the problem.
If all this fails, then we can move to the front of the car. Let me know how you go.
Hope this helps.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory
IH8HSV is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2016, 10:59 AM   #6
bonny
following
bonny is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2016, 11:00 AM   #7
bonny
follow
Old 05-05-2016, 07:24 PM   #8
foxtrot3
foxtrot3's Avatar
Hi. I'm more inclined to think its an earth problem, with the lights off the blinker is earthing through the lower wattage globes which will make them light up and with the lights on power is feeding back from the earth wire into the blinker circuit but the 5 watt park globe earthing through the blinkers isn't enough to make them shine but it will upset the flasher can. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
