Old 09-06-2016, 11:43 PM   #1
twodogs 260
Default au 5ltr power steering hose
Hi all, probably been covered before and have been searching for it but no luck. I have an au 2 5ltr fairlane and i'm pretty sure that the power steering high pressure hose is on it's way out , Has anyone actually replaced theirs themselves and can it be done without pulling the motor to peices or pulling the motor out , handy with the tools just don't see how to do it easily. cheers in advance.
twodogs 260 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2016, 11:30 PM   #2
Supersnake
Default Re: au 5ltr power steering hose
Hey mate, mine was leaking from the o-ring on the high pressure line to the pump. Luckily found I could just replace the fitting on the hose rather than remove it which looked like a pain. Just though I'd add that in case that was your problem.
Supersnake is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2016, 12:06 PM   #3
DartAUxr8
DartAUxr8's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Excellent article on AU IRS rebuild.
its a bit of work replacing this item if your plan is to replace it with a original item. i replaced it on my ute with a used unit that i had in the shed only to find it was also leaking from the seal.
So i just replaced it with aeroflow fittings and hose and it works a treat.
AU XR8 series II
N/A 6 speed manual
426HP 730Nm
1/4 mile: 12.44 sec @ 110.42 MPH
Build thread
http://www.fordforums.com.au/showthread.php?t=11410574
DartAUxr8 is offline   Reply With Quote Multi-Quote with this Post
