Old 12-08-2017, 12:57 PM   #1
boss351290
Default Boss 5.4 thermostat balance pipe o rings
Hello, can someone please help to find the best place to get the o rings on the thermostat balance pipe that runs water between the two heads on the 5.4 boss motor. Mine is leaking a bit of coolant from the o ring on the drivers side head.
boss351290 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2017, 03:09 PM   #2
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Default Re: Boss 5.4 thermostat balance pipe o rings
Get them from America. Summit Racing ect. Usually the pipe is stuffed. They have total replacement kits utilising coolant hose in America.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2017, 04:55 PM   #3
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
What month/year 5.4 do you have as they are different for the RH bank.
1/7/2002 - 30/9/2005 RH: 3L3Z 8C387 AA, LH: 3L3Z 8C388 AB
1/10/2005 on RH: 3L3Z 8C387 AB, LH: 3L3Z 8C388 AB
I think the only one you can still buy from Ford is the later RH one. 3L3Z 8C387 AB.
The cross pipe has a part number of 3L3Z 8C368 LA.
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
