02-09-2018, 11:06 AM | #1 | ||
Hi all. I am currently changing the timing belt on my KH laser 1994 1.8 efi engine.
I have looked everywhere but I cannot find which way to turn the crankshaft bolt(the one near the harmonic balancer)to undo it. On this engine it needs to be undone to remove a plate to allow the timing belt to slip off the bottom pulley. The bolt is not listed as a spare at any auto shop I've called, so I cant get a look at one. Any knowledge / help greatly appreciated. Thanks 280 |
02-09-2018, 11:18 AM | #2 | ||
Hi. In over 40 years in the auto trade I have never seen a crank bolt that isn't a normal r/h thread. That being said I can't for the life of me remember if we had to pull the crank bolt on my sons mazda when we did the water pump. Cheers MD
PS Just remembered, we didn't change the belt as it still looked new from the engine rebuild from the prior owner but We had the pulley off when we did the AC fitting and it was a normal bolt. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
02-09-2018, 11:28 AM | #3 | ||
It's R/H thread the easiest way is to use a beaker bar , rest it against the chassis and crank the engine - don't start it though just "bump" it to crack it.
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
02-09-2018, 12:18 PM | #4 | ||
Hi everyone.
Thanks for the quick responses. I have just organised a breaker bar. I will go with the right hand thread. Foxtrot3 thanks for that info about typically r/h threads. Good to know. I will post when its off. Thanks again everyone. |
02-09-2018, 04:51 PM | #5 | ||
Hi
I used the starter motor method. It worked with a three foot breaker bar and the smallest amount of crank I could give it. Thanks |
02-09-2018, 06:03 PM | #6 | ||
No worries mate just make sure you line up the timing marks before you remove the belt
02-09-2018, 08:16 PM | #7 | ||
Hi
It has all gone well and is back together, but one small potential problem. The lower timing belt pulley is located onto the crankshaft with a 6mm square key about 25 mm long. This key is very snug but is able to move backwards and forwards in the crankshaft / pulley slot about 5 or 6mm. When it does move forward there is only about 10 or 12mm locking the bottom timing belt pulley to the crank. ie 10 or 12mm driving the camshaft. Is this normal? Someone has changed the belt previously and may have fitted a shorter key. Should I be concerned, or is it normal to have this small amount of key driving the cam? Thanks |
