Old 13-03-2019, 05:54 PM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Question AU brake hose question
Hi all got a question for the brain trust.
Need to replace my rear brake hose (I'll post in my build section later why )
So my question is:
Do Ute and wagon hoses fit a sedan? Or is the mounting bracket different
UK
Old 13-03-2019, 06:07 PM   #2
BLU-220
FG XR50 TURBO
BLU-220's Avatar
Default Re: AU brake hose question
So my question is:
UK
Uk are you replacing the hose on your XR8 ??
because if are then no they won't as AU IRS brakets are differnet to non-IRS sedans including wagons and utes
Pm Matt from race brakes to see what he says about it
as when he made up my braIded hoses for the XR8 the LHR bracket was diferent to non IRS
Cheers Dean
BLU-220 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2019, 06:36 PM   #3
Uncle_Ken
Uncle_Ken's Avatar
Question Re: AU brake hose question
Cheers Dean
Thanks for the reply Dean, already talked to Matt today (my 1st port of call)
Thats what I thought but the Ute/wagon ones are a lot cheaper than sedan hence the question. I was hoping that they could fit.
UK
