Old 06-09-2020, 07:47 PM   #1
erniech
Default Cortina Engine Numbers
Hi Everyone.
I realise that this topic has probably been covered before (more than once I suspect)...but being a relative newbie, I need some help and guidance please.
I have purchased an engine that I am told was originally out of one of the Cortina Repco Rally Cars.
Will I be able to tell from the engine number or the block casting number the year and origin of the engine?
Did Australian Cortinas have the same engine # as their chassis number as the Falcons did?
Cheers,
Erniech
erniech is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2020, 08:11 PM   #2
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
Default Re: Cortina Engine Numbers
there are also a lot of active FB groups that might be able to help. Try these to start.
https://www.facebook.com/groups/1375394579362821/
https://www.facebook.com/groups/680123115377846/
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2020, 05:26 PM   #3
Changa
Changa's Avatar
Early cortinas had matching engine and Vin, but i think only up until 1970ish.
The block numbers should tell you more about when it was built and what engine it is. do youhave them ?
Seeya ! Wouldn't wanna be ya !
Changa is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2020, 05:31 PM   #4
chappy60
early cortinas never had matching vin and engine
numbers the vin was on the id plate which should
match the number on the radiator support panel
from about 1969/70 the id was put on the bulkhead
the number on the strut tower on mk2 related to
the engine number but never matching with the vin
the first of the mk2 had a 1300 or 1500 non crossflow
motors still have the id plate off my Feb 67 Gt cortina
which was a 1500 motor sadly the car was scrapped
chappy60 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2020, 06:07 PM   #5
Changa
Changa's Avatar
Originally Posted by erniech View Post
Hi Everyone.
Cheers,
Erniech
Yes. Post numbers here
Old 11-11-2020, 08:31 PM   #6
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
What model Cortina specifically is the engine from?
Theres a bit of info out there on the 79 TE cars, I think I recall a discussion here
http://fordcortina.com.au/newforum/
or maybe here
http://rsmotorsport.com.au/forums/
It may take some digging but the info could still be there.
Escort RS2000 Restored factory a/c and alloys.
TD Cortina Unrestored 35 000km 6cyl manual.
Mk1 GT Cortina Project.
FG XR50 Daily.
Rallye Sport is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2020, 10:37 PM   #7
Paull
P6 LTD
Paull's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all the hard work performed around paint, trim, engine codes in the Classics section. General all round knwoledge and willingness to impart on others
Most of the Ford VIN details are shown here
Paull is offline   Reply With Quote Multi-Quote with this Post
