Old 07-01-2022, 07:47 PM   #1
aaron11
Default Battery charging
Hi😁
New battery when flat a year later .
Car was sitting there for 2 weeks is this normal.
I have 2 alarms.
Also my charger is only 2.5 volt and after 28 hours it was still charging ???
aaron11 is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2022, 08:25 PM   #2
Scruba
15+ Years!
Scruba's Avatar
Default Re: Battery charging
Suspect some drain somewhere. Get a ctek trickle charger and leave it on when not in use. Being a drain may be present maybe need an auto leky to check it out to confirm what is causing the drain.
Sent from my SM-G960F using Tapatalk
AUII Fairmont Ghia Sedan Sparkling Burgandy
Work in progress
https://photos.app.goo.gl/7roViz57bb2Stkzx6
Scruba is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2022, 10:24 AM   #3
Blue Dog
Originally Posted by aaron11 View Post
Hi😁
I have 2 alarms.
Over a period of time a battery will discharge sitting on the shelf, even without being connected to anything.
This is the reason it's possible to buy a brand new battery & it isn't fully charged.
Once you install a battery in a modern vehicle the battery will discharge because it is powering the electronics.
Consequently, if you are driving your vehicle infrequently, or only travelling short distances the alternator will not be able to recharge the battery.
The solution to this situation is to recharge your battery periodically, perhaps as often as every two weeks to keep it in optimum condition.
Two conditions that are guaranteed to shorten the battery lifespan are undercharging or overcharging.
A quality 'smartcharger' that you can leave connected indefinitely is the solution.
You mentioned your charger is only 2.5 volt.
I think you may of meant 2.5 amps, which will charge a standard sized battery.
Obviously a 2.5 amp charger will not recharge a battery as fast as a 10 amp charger & a 10 amp charger won't charge a battery as fast as a 25 amp charger.
Generally a battery will recharge over a 24 hour period.
If your battery has been on charge for 28 hours, the battery may be defective.
Or perhaps your charger is defective.
A battery, charging & starting systems test will determine if the battery is defective or not.
What type of charger are you using?
How do you know if the battery is fully charged or not?
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2022, 09:10 PM   #4
aaron11
Hi Buddy I have the car for 16 years and the battery always has gone flat after 2 weeks.
It has been checked and there was no issues. So I don't know I charged it up and it is fine now, I mean the car doesnt get used at all prob once a fornight
Old 21-01-2022, 09:21 PM   #5
aaron11
Hi the battery charger usually turns off when its done this time it took over 24 hours as it was dead as a dodo
It is ok now but the car sits for a week or two sometimes I try start it once a week.
https://www.supercheapauto.co.nz/p/s...er/577071.html
My charger is like that but about 5 years old, thanks for the help, and the guy at supercheap said every 3 months to take it out and give it a good charge up,
