18-08-2022, 11:50 AM | #1 | ||
Hi, I have 2001 falcon xr8 and the dash lights do not come on, I put another cluster and it works fine, there is 1 light holder missing just a hole i cant get the light in ,with 1 missing will it cause the light circuit to not work. Thanks John.
26-08-2022, 11:55 AM | #2 | ||
Next upgraded Mk1 Leopard
Do you have Forscan?
02-09-2022, 05:25 PM | #3 | ||
No I don't. Thank you.
05-09-2022, 11:50 AM | #4 | ||
search the forum for it. Its a free program and it could find an error to help with the cluster . Try cleaning the globe housing it might stop the currant. Also try looking at the board with a magnifying glass and look for fine breaks
05-09-2022, 01:41 PM | #5 | ||
Regular...with metamusal
forscan best to use a windows based laptop, but up to you what you actually use. with the free software you don't get to use everything but you can get a temporary license [for 2/3 months] that allows you to make full use of the program. hava good read about it 1st so you get an idea of what it's about. compared to the 'B' series cars you may not be able to read everything in the AU [didn't try it out on me 'Ol yella [AU wagooon]. but it should prove useful. |
10-11-2022, 04:42 PM | #6 | |||
Red ones go faster!
Cheers Wayne |
