Old 28-11-2022, 06:35 PM   #1
nicrobell
Default Climate control fail
Just wondering if anyone has had issues with the climate control on their 2015 Mondeo Titanium? I can only get cold air with the temp controlat LO position. As soon as the control is raised above this position the system blows hot air.
I would appreciate any advice to solve this problem.
nicrobell is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2022, 09:34 PM   #2
Mondaveo
Mondaveo's Avatar
Default Re: Climate control fail
Just guessing, could be faulty temperature sensor/thermostat? Such things will usually return a reading of zero when they fail, in which case the HVAC will think it needs to pump out hot air to warm the cabin up (unless you explicitly command cold by turning the dial to LO).
Connecting an OBD tool with FORScan may help you confirm this hypothesis by viewing the cabin temperature reading (and a number of other parameters) from the control module.
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
