Old 28-01-2025, 06:46 PM   #1
nfitbh
Default My clean XR4 with a voltage issue
Very excited a couple of weeks ago to pick up an XR4. 2008 with only 34,000 kms on the clock!
Attachment 107766
One lady owner from new, full service history, serviced every year (even if she only did 200 kms in that year). No mods, the exterior and interior look almost showroom. (Engine bay has had less love, it will get that soon.)
Unfortunately was driving back from a mate's place (he lent me a ODB2 scanner) when suddenly the dash lit up like an Xmas tree and then the car cut out. Fortunately in a suburban area, I wasn't doing 110 or anything.
Well the scanner came in handy, showing 8V of charge.
And got towed home :(
Have a charger, will use it overnight. If the battery holds charge then guessing it will be the alternator? If not, then new battery required?
Is it that simple?
nfitbh is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2025, 08:18 AM   #2
nfitbh
Default Re: My clean XR4 with a voltage issue
Battery reading 12.4V (in car), so assuming it's time to fork out for a new alternator.
Any recommendations?
eBay's listings are all from Latvia, guessing Ford have a factory there?
Old 29-01-2025, 10:31 AM   #3
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Originally Posted by nfitbh View Post
Battery reading 12.4 V (in car), so assuming it's time to fork out for a new alternator....
12.4 V is battery voltage (i guess you charged it up with a charger overnight), it should be a bit higher than that with a good battery after a proper charge, say 12.6 -12.7 V.
Did you measure the voltage at the battery with engine running? Should be around 14 Volts or more witha good alternator..
So yes the alternator may be dead, but its very strange that the alternator would fail after only 34,000km, so well worth making sure there is no loose or bad connections in the wires on the back of the alternator or on the battery. I would think its more likely the battery is dead from sitting around doing nothing for years, rather than being the alternator. So measure the alternator output when engine running.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2025, 05:08 PM   #4
nfitbh
Originally Posted by AMB View Post
Did you measure the voltage at the battery with engine running? Should be around 14 Volts or more with a good alternator..
yeah, the voltage varied between 10.5V and 12.4V whilst running - measured using a ODB2 scanner.
probably completely unrelated, but for the last couple of days there's a bad smell coming (like burning rubber) from the engine bay and a bit of a whining noise, could be a belt problem?
anyway, next step mechanic, not going to drive a car around where the battery isn't accepting charge and a burnt rubber smell is coming from the engine bay lol
Old 12-02-2025, 09:07 PM   #5
nfitbh
update: yes it was alternator, apparently they had to take the front right wheel, hub, etc off the car to get to it, $1,400 later :(
doesn't smell, and a charge of 13.8V (in car) whilst running.
it's so much fun to drive, love this little thing
