Old 01-09-2007, 09:36 PM   #1
aufutura_bloke
Default AU series 2 Rear Tail lights
can someone tell me how to replace the bulb in my drivers side rear tail lght. i have not long purchased the car and have not yet bought a work shop manual. Thanks fo ya help
aufutura_bloke is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2007, 09:43 PM   #2
b2tf
not here much anymore
b2tf's Avatar
You'll have to remove the entire taillight - 2 screws near the bootlid side (take a look at it and youll see what I mean), and one plug that pushes in near the corner of the taillight where it meets the rear quarter if you get me. Undo the 2 screws, then carefully pull the taillight out (it will take a bit of work), then you can get to the loom - unscrew the caps, remove bulb and replace.
2024 F150 XLT
Old 01-09-2007, 10:00 PM   #3
aufutura_bloke
ok ill have a go at it sounds tricky. i like the old XF tailight Bulbs they were easy to replace you never had to take the whole tail llght out. im guessng the bulbs used in the au falcons are standard and not diffrent.
Old 01-09-2007, 10:03 PM   #4
partie
its really not that hard. Much easier than the EA-ED tail lights. All the screws are accessible without the need to remove other panels.
About a 1minute job.
partie is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2007, 10:03 PM   #5
b2tf
b2tf's Avatar
yeah, standard bulbs. it sounds harder than it is.
2024 F150 XLT
Old 01-09-2007, 10:09 PM   #6
aufutura_bloke
I have found the 2 screws facing the boot lid.then there are two bolts with nuts on them do i undo these? on the back of my tail light there are two plugs going into the tail light from the boot. do these just pull out?
Old 01-09-2007, 10:29 PM   #7
aufutura_bloke
DONE YOU WERE RIGHT MATE UNDER 1 MIN JOB. Easy as
Thanks for the help good to know that people can help other people via ere, hope one day I can help you out
Old 01-09-2007, 10:52 PM   #8
b2tf
b2tf's Avatar
glad you got it worked out :
2024 F150 XLT
