Old 14-07-2005, 03:53 PM   #1
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Unhappy BBM hitting bonnet on ED
Heres a couple of pics of the BBM on my ED where the manifold has hit the bonnet :
Has anyone had the same thing happen???
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 03:57 PM   #2
neb
hibernating
neb's Avatar
is your passenger side engine mount ok? maybe the engine is lifting up when you rev?
neb is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 04:00 PM   #3
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
How do I check that?
It rocks a little in neutral, but all 4.0L do.
Daily driver
Other
13.75 @ 101mph
Old 14-07-2005, 04:01 PM   #4
neb
hibernating
neb's Avatar
check if the engine moves much when you give it a rev.. or have alook under the car check if the rubber on the engine mounts is ok and not broken. i wouldn't think that it would usually hit the bonnet otherwise
Old 14-07-2005, 04:49 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
Mine is clear, hasnt hit the bonnet at all, but I did have a broken passenger engine mount when I had my engine out ages ago, and is replaced, so neb may be on the right track i reckon.
Old 14-07-2005, 05:18 PM   #6
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Engine was out and fully rebuilt in November, so I'm hoping its not a broken engine mount, too wet today to get under the car and check.
I should note though the manifold was hitting the bonnet at the drag strip I assume during the burnout so maybe its just one of those things.
Daily driver
Other
13.75 @ 101mph
Old 14-07-2005, 05:29 PM   #7
TUFED6
TUFED6's Avatar
Would say its almost certainly a busted engine mount.
They aren't strong, I've broken several of them. I broke one once when I missed a 2nd-3rd shift. Engine tried to climb out of the engine bay and rocker cover hit the bonnet putting a nice big dent in it. Stupid crap.
Only solution is to limit how much they can stretch.
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 05:42 PM   #8
Sox
RIP...
Sox's Avatar
Engine mount.
Rick.
Oval Everywhere...
Old 14-07-2005, 06:12 PM   #9
NZ
NZ's Avatar
put ya handbrake on, in gear and stall up the clutch get someone to watch it lift up
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 14-07-2005, 06:30 PM   #10
OED666
OED666's Avatar
if you nail it in second, does the gear shifter move from the left to the right??? another sign the engine mount is cactus
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 06:59 PM   #11
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
my engine mounts are fine (new even) and my gear shifter moves a fair bit...
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 09:13 PM   #12
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Gear stick is dead still in all gears.
Daily driver
Other
13.75 @ 101mph
Old 14-07-2005, 09:24 PM   #13
chrispie123
v8 Bulge :P
chrispie123 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 10:17 PM   #14
blwneb
come join me
blwneb's Avatar
Engine mount is broken or needs replacing.
blwneb is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2005, 06:23 PM   #15
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Thanks for the replies people, I will get under the car and check as soon as it isn't so wet around the car
Daily driver
Other
13.75 @ 101mph
