Low and Loud
Ive had the EL thermo's in the car for a while now and have noticed that they are ****ing me off.
They seem to come on ALOT at idle, they are draining the #@$!! out of my battery and no matter what I do still does it. The same wiring on John_xr6's ED and Dellboy's EA doesnt have this issue. The Volt gauge is showing 13 and slowly drops to 12, this is shown also on the Multimeter when I check it at the battery and Alternator. Tonight it was the last straw when it went UNDER 12 volt! Ive EVEN tried different alternators and even a new battery! Will I loose any power if I go back to the trusty Clutch fan?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
Custom user title
Where are the fans getting there power from.. IS the earth and power straight to the battery via a relay of course, With the trigger just earthing the realy... I found this was the best way, i used to just have the fans getting a ground from the body, i found drawing 40-60 amps on startup wasnt a good idea through body earths.
#3 | ||||
Low and Loud
The fans are wired up exactly how specified via the "craig davies twin thermos" wiring diagram
The one and only
Check all your earths. It sounds silly but a fans are running past the cars limits and the linit may be somewhere else.
Make sure the earth from the battery to the chassis is good. Clean the terminals on the battery and the terminal on the chassis. It is good to remove paint.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
Custom user title
have u tried the fan power directely from the battery and not the alternator?.... not sure if it would make a differnce
RIP...
The fans should be getting power from the battery, not the alternator.
Also, the fans are supposed to come on when the engine is idling, as that is when they are needed most. BTW, 'INJECTED250' earth should be left via the chassis, 40-60amps is nothing, how much current do you think the starter motor draws.... Rick.
. Oval Everywhere... |
The one and only
The alternator runs the car, not the battery!
It make no difference whether you wire it to one ot the other as they share posative. Unless the wire between is to small. I upgraded mine to 8G. You will find the fans aer not the problem, but they are showing it. Find the fault first.
#8 | |||
my other ride is the bus.
Have you tried re-adjusting your thermatic switch?
1994 ED Fairmont Ghia (Retired to the shed...) 1999 AU Futura + Lots of Land Rovers Quote:
#9 | |||
RIP...
Rick.
#10 | |||
The one and only
Check power at alt and at batt using batt neg with fans on. There should be no difference in voltage. Changing the wire for the alt to the bat will not show if the alt is 'running out of puff'.
#11 | |||
RIP...
I'd prefer to see this connected directly to the battery, as that's where the least resistance to large current will be. Rick.
#12 | ||
it could be the fans are getting old ???
#13 | |||
Low and Loud
The wierd thing is while the car is actually in motion (driving around) there is NO voltage drop but soon as i am about to stop the voltage drops? Almost like the thermos are not draining as much current when they are being assisted in moving via the wind? or is that just a stupid idea... ![]() When the car is actually not moving i have to do 1500rpm for it to charge at 14v. The Alternator is reco and ive tried 2 other ones aswell.
#14 | ||||
RIP...
Alternators only produce peak current at 1500rpm or so. Quote:
Has the battery actually gone flat, or are you just worried about the gauge reading low? Rick.
#15 | ||
put ya clutch fan back on. :P They rock!
#16 | |||
Low and Loud
#17 | |||
Custom user title
But if all is good there is no problem using the body.. as long as the earths from the body to the battery are nice and chunky and connected .. it Last edited by INJECTED_250; 04-08-2005 at 12:23 AM. |
#18 | |||
RIP...
Question for you, is there a earth cable going directly from the starter to the battery? If not, where is earth for the starter coming from. Hint: Read what you wrote above. Rick.
#19 | |||
RIP...
However, has the battery gone flat, or has it been unable to start the engine? Rick.
#20 | |||
Custom user title
If this swaged join is un bolted from the body it will still crank fine rick so i dont see how u figure engine is earthed through the body then to the battery which is what u are saying. This would require 2 seperate lengths of wire connected to 2 differnt points on the body one from the starter tothe body then one from the body to battery in differnt locations to flow any current under crank between these to points . as you can see rick this is not the case enjoy :> ![]() .. |
#21 | ||
RIP...
Yes, in this instance, the manufacture has used a continuous wire from >battery>chassis>engine. However, the chassis is still the common ground point. Think of cars with an earth strap running from the engine to the chassis. Think of boot mounted batteries. Think of trucks where the batteries are mounted meters away from the engine. In all of these instances, a long positive feed runs from the battery to the starter (or more usually, a junction). And the negative from the battery takes the shortest path to the chassis. The engine block then has an earth strap. Earth is not run to the engine block in these cases, and of course is not needed. I know what you're saying, but that's doesn't change the fact that the best earth for the electric fans will be chassis, not the negative battery terminal, as this just creates an unnecessary long wire. Rick.
#22 | ||
The one and only
This is the earth that needs to be upgraded. The connection to the chassis run the car, the loop to the engine runs starter, sendors and alt. This wire has to be at least the size of all the wires from the posative!
#23 | |||
Low and Loud
#24 | ||
Does Steve have a car?
Time for a serpentine belt drive conversion :P
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
#25 | ||
eec tweaker
i never needed both fans to come on to keep my car cool. and i had a old radiator. try using one with the aircon, one with the thermoswitch.
#26 | |||
Low and Loud
I thought maybe of having one of the thermo's running off a switch on the dash, so if the one fan cannot do enough, I can simply switch the other on. If i was to do it this way, what fan would you recomment comes on first? the inlet or exhaust side?
#27 | ||
Low and Loud
Rollin
Alternator belt is fine and tight, i ONLY have voltage lost when the thermo's are on. Cooling system appears to be fine (new thermostat, water pump, flushed radiator and has new coolant)
#28 | ||
eec tweaker
i never needed more than one fan in the 4 years i had my EA.
you should have one wired to the aircon anyway, because you risk high system pressures and blowing up your compressor if you let the condensor get too hot. Jason |
#29 | ||
XE Freak!!
run brand new + and eaths to ur thermos, tap into ur brake light switch on ur pedal, and weneva u brake the thermos will come on, that way if u stop there isnt wind to go thru the radiator, but wen u stop u are sending power to the thermos turning them on, will keep ur car cool and u should experience the voltage drop, the voltage drop is caused by too much resistance in the wires, so if u dont wanna wire them up to the brake like feed then run ur earth the same size as ur + or replace both wires as they could be corroded.
#30 | ||
Mr Extraordinary
what speed does your car idle at? what is the amp rating of the alternator? (alternators have a regulator in them so that they wont charge till over a certain rpm.)
i have no idea why people are raving on about the earth wires to the thermos. check the positive wire from alternator to battery tho. or it could just be that you've got an older alternator that literally cant produce that kind of current. heres a test, get car to idle with thermos on.. then put the lights on, highbeam too... does the voltage drop even more/faster? if so then your alt is probably too small. |
