Old 03-08-2005, 06:57 PM   #1
xr8chaser245
Unhappy Header Gasket Headache
HI guys. i have a problem trying to get header gaskets( head -extractor) to suit my series 1 AU xr8 - now the problem is not the fact of getting them but getting them to suit my heads , 1st try was repco - right part number and gasket but the port holes were to small
2nd try FORD GENUINE -same problem
3rd try PACEMAKER -GUESS WHAT ? we dont do them
so what i found was - that all gaskets come standard size , so if i put them on i risk choking the bloody thing, i have 44mm ports in my heads and the standard gaskets are way to small, so now my only option is to track down the guy who oriinally put the exaust together so i can find out where he got the gaskets from( big task)
if any one has any ideas it would be much appreciated out:
Old 03-08-2005, 07:06 PM   #2
aimzes
...fairly odd
aimzes's Avatar
could you modify the gasket? make the holes a little bigger?
1992 EB Falcon 5.0 V8. mods; dust, dirt, cobwebs, scratches, trolley dents, dented bonnet, gutter scrapes, rattly exhaust, and floor mats.
aimzes is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 07:18 PM   #3
xr8chaser245
I thought of doing that but i am not one to mess with nature, it looks like i may have to go back to the old gtho gasket if i cant get any more sense out of these people that call them self experts :SaiyanSmi
Old 03-08-2005, 08:00 PM   #4
AUXRVIII
What about a liquid sealant. Loctite make some good products for this purpose. One of them is Loctite 5900, comes in a tube to be used with a caulking gun.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 09:43 PM   #5
EDXR8
EDXR8's Avatar
I was told by Pacemaker and a number of mechanics to just use silicon gasket maker as that seals much better. I used ultra copper the one with the highest temp rating and it has sealed up very well (use to blow the gaskets quite regularly).
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 11:12 PM   #6
XRated
Shoot.
XRated's Avatar
Yeah I don't think you need gasket, just a very good sealant. If I'm not mistaken, most header/performance companies recommend this.
20V Turbo
Old 03-08-2005, 11:17 PM   #7
brenx
brenx's Avatar
Spot on. I just use a high temp silicon on my. No leaks till a workshop sealed it using normal silicon. It hadn't leaked in 2 years prior.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2005, 05:21 AM   #8
xr8chaser245
allrighty then , it sounds like a plan, i will give it a go. hopfully that should fix the problem.
i will let you all know on the weekeend how we went and how much skin is taken off the knuckles, cheers
