Just stuffin around today trying to make my t5 howl less and last longer, i found that my 5 speed takes dexron II (acording to the owners manual) instead of gear oil. Is this common with many manual transmissions? Anybody else not know this or have i had my head buried in the ground again?
I reccon someone else didnt know because the colour of the oil was a bit suspect! |
ooga-lagga-ligga-lagga
yeh my kb laser also takes dex 3, although atm its got 75/90 gear oil. i will be changing back to dex 3 as its harder to change gears with the thicker oil
Check the manual again, you'll probably find as well as the dextron II you'll need an oil additive (Lubrizol 7906)
Ford ran the trans fluid and additive for better shift feel.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
BPTMOTORSPORT.COM
Just put the trans oil straight in mate.Its what they run nowadays, exactly what fairmont said with the changing factor.Ive ran in my EDXR8 since the day I bought it.Runs a treat.
Terry
1994 EDXR8 Pearl Black BPT Motorsport built 347cuin & Kennebell Boosted 345rwkw and 950nm torque |
NOS Induction pssssshhhhh
I`m not sure if all the manual gear boxs use the same oil i no from ea to ed they use DEX 3 not sure about the ef and el boxs, i`ve always used the Dex 3 oil and never used an addictive.
STOKEB - 3:7 diff gears, 3inch zorst, JMM Race Series Extractors, Custom Bottom end to suit N20, AU DEV 6 Head and Cam, Cold Air Intake, ED XR6 Manual Computer with Flash Tunner, ED XR6 Fuel reg, C10 Auto, 2800stall . --------------------------------------------------- I LiVe My LiFe A bOtTlE aT a TiMe, FoR tHoSe 200 sQuIrTs I fEeL fReE.........pssssssssssssshhhhhhhhhhh |
Former E-Series Member
Personally I think fully synthetic is worth spending extra on, I'd only use Castrol Transmax Z. Good fluid is cheaper than gearboxes.
