Old 24-08-2005, 05:29 PM   #1
Kaddis
Kaddis Customs
Kaddis's Avatar
Default help with pulling apart DIFF! URGENT HELP!
does anyone know any good sites with info on taking apart diff's?
caus i've taken the disk's off/calipers so far but need to know how to get the axles out so i can change the center because mine packed up and i need to replace it ASAP! my brother is going to do most off the work but i want to get a head start on it because so far i have no way off getting to work the next few days!
thanks!
FG XR6 E-Gas Ute in Ego
Kaddis is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 05:58 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Have a look at the ends of the axles, there is a hole in each end where you can fit a socket into. There's 4 bolts holding the retaining plate in, undo them and you're on your way.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 06:09 PM   #3
MAD
Petro-sexual
MAD's Avatar
After you have taken those 4 bolts off, if it still wont come loose, what you can do is put the disc on backwards over the studs, put a couple of nuts on a little way, then use the disc as a slide tool to remove the axle. Works a treat!
- The Story
Old 24-08-2005, 06:52 PM   #4
Walkinshaw
Two > One
Walkinshaw's Avatar
are you going to pull the centre out???
have fun...
Old 24-08-2005, 09:01 PM   #5
hornet
hornet's Avatar
If you have ABS, don't forget to remove the sensors first.. otherwise you will be like me and have a "Check ABS" light on your dash :(
Taking the center out is easy, just undo the 4 bolts holding the bearings in, and use a big pry bar to gently pry it out. Well it worked for me
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 09:34 PM   #6
Kaddis
Kaddis Customs
Kaddis's Avatar
yeh well whats happend is the diff that is in it now if f#$ked and gotten to the point were i cant drive it so it's sitting in the garage now.
but i've got another diff in there which is a normal GLi 3.08:1 diff and i've got an 3.45:1 LSD center because the 3.08:1 center is rooted so im trying to change the centers over ASAP!@!@
