Just thourght i should let all you guys know how i solved the problem of dryed Interior door handles.
all i did is go over them with some wet'n'dry until it when't smooth, Hence it removed all the dry flaking plastic, I also did the same to the demister switch and now it looks like new. ![]() |
I Wish I Was A Post Whore
can we see some pics?
Low and Loud
thats great, wouldnt do it too often cause after a year or two there might not be any plastic left LMAO
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() Last edited by InitialD; 03-09-2005 at 10:40 PM. |
LAYM: sorry i haven't got a digitil camera only the film one
INITIALD: it took 12 years to dry out so it should last at lest 8 years,hopfuly ![]() |
#5 | |||
Shoot.
Maybe a couple of coats of some type of sealer to finish them off, or even a lick of paint too?
20V Turbo |
This wet'n'dry everyone talks about - what the hell is it and what does it do ??
windsor user
wet/dry sandpaper
its very fine grade sandpapers you use with water |
likes falcon's
u could always chase up some better condition door handles
www.carhubsales.com.au |
#9 | |||
Were do you get the little plastic caps that do over the screws?
#11 | |||
![]() Join Date: Jan 2005
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#12 | ||
what about new ones?
#13 | |||
#14 | ||
great thanks mate
#15 | |||
V8 Ghia & BF2 XR6 + Wagon
They're hard to constantly remove without wrecking them. sucks.. |
