Old 08-09-2005, 04:34 PM   #1
nat_daly
Nat D
nat_daly's Avatar
Default help! paint fixing needed
hi everyone
i s ratched my rear bumper ages ok and ive now put touch up paint on these scratches just today..
however the touch up paint is not glossy?
is there any product i can buy that will gloss the touch up paint a bit? even gloss that works on normal paint perhaps?
is there anyway i can get the touch up paint more glossy so that it blends??
all help is appreciated
thanks
Nat D
nat_daly is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 04:34 PM   #2
gozza
gozza's Avatar
clear coat
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 04:36 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
have you tried to polish/wax it, paint needs buffing to become shiny, it doesnt spray on shiny really.
Old 08-09-2005, 04:36 PM   #4
richo77
richo77's Avatar
trying polishing it a few times after its had time to cure properly before going to clear coat mate
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 04:39 PM   #5
nat_daly
Nat D
nat_daly's Avatar
i did the polishing a while back and it dosent work....
it sucks having a black car some times..
clear coat? what does it do and how much?
Old 08-09-2005, 04:40 PM   #6
nat_daly
Nat D
nat_daly's Avatar
lol what dosent spray on shiny?? the touch up?? or clear coat?
Old 08-09-2005, 04:42 PM   #7
EA2BA
PM me if you want
EA2BA's Avatar
no more then 10 in a can, tape up the area so as to have minimal over spray, then go for it, buff and polish to make it look normal. lots of light coats with a little dry time in between are better then one thick coat.
Old 08-09-2005, 04:43 PM   #8
nat_daly
Nat D
nat_daly's Avatar
are you talking about clear coat??
if so how much will it cost, and where to get it from?
Old 08-09-2005, 04:45 PM   #9
richo77
richo77's Avatar
the brush touch up should be glossy, if you are spraying metallic paint from a can, it will be dull cos you have to put the clear coat over it
Old 08-09-2005, 04:45 PM   #10
EA2BA
PM me if you want
EA2BA's Avatar
sorry my bad typing today
I meant no more then $10 for a can, and yes i was talking about clear coat.
Old 08-09-2005, 04:46 PM   #11
nat_daly
Nat D
nat_daly's Avatar
negative.. i can tell you this brush touch up is not glossy..lol
do these expire or anything?
Old 08-09-2005, 04:46 PM   #12
nat_daly
Nat D
nat_daly's Avatar
thanks heaps buddy..
where would i be able to get it from?
Old 08-09-2005, 04:47 PM   #13
EA2BA
PM me if you want
EA2BA's Avatar
k-mart, any auto store.
Old 08-09-2005, 04:49 PM   #14
nat_daly
Nat D
nat_daly's Avatar
becaus it is a large area, and some of this area has scratches and some dosent will it matter if i mask off whole area and spray the whole lot.. so i will be spraying the already normal coat aswell?
Old 08-09-2005, 04:52 PM   #15
EA2BA
PM me if you want
EA2BA's Avatar
It wont matter, BUT if you plan on doing that then make sure all wax/grease etc has been removed first, and also give a light wet'n'dray sand with say 1200 to the area first to allow the paint to stick properly.
I would suggest posting some pics up, or a better description of how big an area affected, so you can get better advice before you may end up with a bigger area that stands out, black is so hard to work with, but looks so good too.
Old 08-09-2005, 05:10 PM   #16
nat_daly
Nat D
nat_daly's Avatar
i would but photobucket is unavailable at the moment..???
its about 30cm by 30 cm
Old 08-09-2005, 05:26 PM   #17
nat_daly
Nat D
nat_daly's Avatar
here are some pics..
Old 08-09-2005, 05:47 PM   #18
Kryton
Kryton's Avatar
crap!!
good luck with that!
id be taking it to a spray painter for something that big.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 05:49 PM   #19
nat_daly
Nat D
nat_daly's Avatar
thanks for the luck
lol
Old 08-09-2005, 06:54 PM   #20
Blue Oval Mopar Man
Has Blue Blood
Blue Oval Mopar Man's Avatar
Nat if you want it to look like new ,go to a panel shop ! Sure it will cost a couple of hundred but at least it will look great !
Or if your comming up to Darwin anytime soon , I do paint and panel myself ! hahahahahaha
Real cars dont wear bowties
I'm not arrogent , Just superior
Blue Oval Mopar Man is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 07:18 PM   #21
b2tf
not here much anymore
b2tf's Avatar
Those marks are way too big to try and just use touchup paint on. You'll ruin the bar.
2024 F150 XLT
