Old 11-10-2005, 08:19 PM   #1
NARCEA
5/00 AUII Forte
Default ea annoyance
Hi guys,
More of a frustration rather than a problem....
There seems to be a flat spot in my acceleration from stand still. Seems to happen more when she's running hot.
I sit at the lights.... they go green, and I accelerate gradually but there will be a hesitation in the car and then suddenly it'll kick in.
Any suggestions to what I should be looking at?
3 speed cfi.... running beautifully besides that.
Cheers,
Ian
05/00 AUII Forte
NARCEA is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 08:21 PM   #2
JUZXR8
Hmmmmm
JUZXR8's Avatar
it just before it changes gear?
if so then it could be your tranny clutch
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 08:31 PM   #3
NARCEA
5/00 AUII Forte
its from the moment i accelerate..... it just feels like a huge hesitation.... but it'll kick in maybe after three seconds. cheers
05/00 AUII Forte
Old 11-10-2005, 08:59 PM   #4
xxxc
tuff
xxxc's Avatar
so what would that mean elrooto transmission?
.......................FG XR6 UTE...........................
......................xc fairmont gxl.........................
...................GQ coil cab UTE ..........................
xxxc is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 09:01 PM   #5
JUZXR8
Hmmmmm
JUZXR8's Avatar
....i mean correct me if im wrong but dont all transmissions have a clutch.......maybe the band is worn and needs replacing....true?
Old 11-10-2005, 09:07 PM   #6
NARCEA
5/00 AUII Forte
transmission was serviced seven months ago....... passed with clean bill of health. i might get them to look further into it then when it gets looked at again.
would there be anything else besides tranny?
05/00 AUII Forte
Old 11-10-2005, 09:07 PM   #7
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
quite possible the tps, mine used to do that too, symptoms were a lag before acceleration and the auto not kicking down, remember on the EA's the TPS has 2 outputs controlling both. i had a play around, got one from a wreckers and it came good
then i did an mpfi conversion
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 11:33 PM   #8
sphell
sphell's Avatar
disconnect the oxy sensor and see if that makes a difference. if it does it's rooted.
Old 12-10-2005, 10:36 AM   #9
Paris Hilton
Custom User Title
Paris Hilton's Avatar
Originally Posted by NARCEA
Hi guys,
Cheers,
Ian
Exact same problem except mine's a 5 speed MPFI, i've disconnected the oxy sensor, and changed leads and plugs to no avail :
Paris Hilton is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 10:39 AM   #10
EA2BA
PM me if you want
EA2BA's Avatar
Its a 3 speed auto so has manual kickdown, and will only have one TPS, so reasonably you would have suspect the gearbox, but they are pretty hard to kill.
Whats the fuel consumption like, how mnay k's do you get out of a tank.
Old 12-10-2005, 12:08 PM   #11
NARCEA
5/00 AUII Forte
cheers guys for the info....
kickdown is working fine..... Sometimes I feel the box holds third for too long when slowing down...... but I'm told this was to help improve economy. the gearbox changes smoothly while driving... although there's a noticeable clunk when shifting between p-r-n....... universal joints???
fuel consumption....... recentlying on a trip down south I worked it out to be 8.5km/L....so around 510km to 60L if my calculations are correct. This was mixture some country, some stop start.
around town...... not so crash obviously. Last time I worked it out to be 6.7km/L so around 400km to 60L if I get a good run.
ian
05/00 AUII Forte
Old 12-10-2005, 12:18 PM   #12
NARCEA
5/00 AUII Forte
is it the case of the 3-speed cfi set up or does something not sound right? I've been meaning to drive another one to suss out whether it's a problem or not but most EA-loving folks around here have the 4-speed.
05/00 AUII Forte
Old 18-10-2005, 04:15 PM   #13
Paris Hilton
Custom User Title
I've changed plugs and leads, and it helped, but not down really low (when the car is cold) is flatspots big time...only sometimes though, and only when taking off in 1st...any ideas?
Old 18-10-2005, 06:03 PM   #14
dansince86
hey kids, i also suffer from this frustration, it almost feels like it has electronic throttle controle and it takes its sweet *** time to get to the brains to say "go ". however to get rid of 80% of the lag i just stall it up to about 1000-1500 rpm, i'm to sure about all this tichnical talk, however i do plan on tightening my excelerator cable so it sits @ like 800rpm rather than the 400/500 mark, i'm tipping since the cars are over 15 years old the cable has stretched. get back to me NARCEA if u find the problem, i alkso hav the 3 speed :p
dansince86 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2005, 06:41 PM   #15
JUZXR8
Hmmmmm
JUZXR8's Avatar
how do you tighten the accelerator cable?
Old 19-10-2005, 02:09 AM   #16
dansince86
if its anything like anyother ones i have worked on, find where the cable is, and where it inputs into the engine, there should be a spring system, and an adjustable hollow bolt type thing that cablke runs through, expand that and it should take up any slack in the cable, an easy fix to stop slow idleing cars
