Old 29-10-2005, 06:26 PM   #1
347Stroker
347Stroker's Avatar
Default Thermactor Port block off inserts wanted
As the title says, the thermactor port on the heads needs to be blocked off, and the plug has an internal thread, does anyone have 4?
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2005, 06:36 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
Just use a unc bolt with loctite....
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 29-10-2005, 07:02 PM   #3
347Stroker
347Stroker's Avatar
I would if I didnt need the thread up inside the inserts....
Old 29-10-2005, 07:04 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
Screw out the insert as I had done with my Trickflows (Thats if they are the same) if not ill go hide under my keyboard
13.21 @107.7mph
