Old 04-11-2005, 05:37 PM   #1
sickxr
Ford POWER!
sickxr's Avatar
Default Loud crunch noise
Hey people! My AU2 XR6 Manual has started making a loud noise when i boot it hard : It tends to do it easier when im turning aswell. It does sound like its coming from the rear drivers side. I will get under it tomorrow to check it out and see if anything looks sus but i was wondering if any1 else has had this b4?
The car has only done 70k aswell!
Thanks
sickxr is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2005, 01:58 PM   #2
DJM83
Barra Turbo > V8
DJM83's Avatar
is it a VCT if so check the rear shock mounts in the boot more then likely they are stuffed
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 05-11-2005, 05:14 PM   #3
sickxr
Ford POWER!
sickxr's Avatar
Nah mate its a HP. I serviced it today and checked out the rear end and everything seemed fine!
Old 07-11-2005, 10:04 AM   #4
sickxr
Ford POWER!
sickxr's Avatar
Would it make a difference if i had a full tank of fuel? It wont make the noise when i have a full tank
Old 07-11-2005, 04:29 PM   #5
AU-MUSTD
Flat floor shifter
AU-MUSTD's Avatar
The spider gears went in my ba lsd diff after about 15,00 and would make a god awful noise when turning only.
AU-MUSTD is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2005, 04:41 PM   #6
xbcoupe302
formerly xbwgn
i get a loud cracking noise from the my au11 manual if i get up around 3500rpm and dump the clutch it make a horrible crack from under the car somewhere.
and if i gear down coming into corner eg put it in 2nd at 80klms it makes the same noise.
my solution is i will wait for it to break whatever it is then i will know what the noise was
Member of the 250rwkw club.
weekend driver XB COUPE
daily driver ZH FAIRLANE
project cars V8 XB WAGON
V8 WINDSOR POWERED BLUEBIRD WAGON
wrecking v8 XD WAGON
xbcoupe302 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2005, 09:58 PM   #7
sickxr
Ford POWER!
sickxr's Avatar
Yeah thats sounds like it! How long has it been doin it for? If whateva it is breaks make sure u pm me mate :1syellow1
Old 08-11-2005, 09:39 PM   #8
XR_Strider_GuY
Boss for Go, L98 for Show
Contributing Member
XR_Strider_GuY's Avatar
Thanks
Could be a number of things, do you feel the whole rear end banging? If so it could be axle tramp mine has done it (when provoked since new) but i've got it sorted now.
Quote: Jeremy Clarkson "The fact of the matter is this, from just about any angle this is an impossibly pretty car"
XR_Strider_GuY is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2005, 09:45 PM   #9
xbcoupe302
formerly xbwgn
no mine sounds like its coming from under the seats somewhere.
sick xr i will pm u or if yours breaks first pm me
Old 16-11-2005, 10:48 PM   #10
stiddy
stiddy's Avatar
Ive got that exact same noise..
sounds more like your snapping a tooth on the diffgear or something lol..
but its definately from the rear under the car, i get it when i dump from anything over 3500rpm, or suddenly boot it around a corner.
I too would like to know what it is........
went into a diff place, nothing was found.. had suspension checked nothing was found.. still got that snapping sound...
Old 17-11-2005, 08:17 PM   #11
wild6
wild6
wild6's Avatar
hey xr strider guy how did u sort out ur axel tramping mine has done it since new as well when provoked in 1st
regards from adam
series3 xr8 manual, 347 stroker, twin throttle, heads and cam , lowered, custom interior, 3.9 diff gears
still running her in!
Series 2 Venom AU TE50 Manual Lowered twin 2.5 inch exhaust
wild6 is offline   Reply With Quote Multi-Quote with this Post
