Old 09-11-2005, 08:36 AM   #1
diesel17
Default power steering rack leaking
I have a 2001 au2, I got it serviced at the local Ford dealer. They told me it needs a new power steering rack and tie rod end boots are split. I check my car every sunday and I have never had to put power steering fluid into it, there are no marks anywhere on my driveway! They then quoted me:
Steering rack $570
tie rod boots $112
Wheel align. $40
Labour $130
TOTAL $852.00
I can get a 2nd hand steering rack from a au2 thats only done 39,000kms for $195.00 and the local mechanic to fit it and wheel alignment $80 for a total of $275.
Or do I get a second opinion on the faults by some one else before I do anything?
I would welcome some opinions on what I should do!
Thanks Diesel
diesel17 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2005, 08:46 AM   #2
bprint xr8
more posting less lurking
bprint xr8's Avatar
If its not leaking, check the rack boots to see if they have fluid in them. Usually you will be able to feel the fluid just by giving them a squeeze. If there's no fluid there then it would appear to be ok.
BA XR8 Devil R - SY Territory TX AWD - MQ Nissan Patrol 302c - GQ Nissan Patrol
bprint xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2005, 09:10 AM   #3
Sourbastard
Contributing Member
Sourbastard's Avatar
Ive got the same thing happening in my 2001 AU2. One day ill fix it.... promise.
1965 XP Falcon Deluxe Sedan
2003 BA Fairlane G220
Old 09-11-2005, 10:25 AM   #4
xr8 007
xr8 007's Avatar
hey wasnt there a recall for the racks on the auII????????? mine got changed for free.
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2005, 11:24 AM   #5
xr8ute
Back on the road
xr8ute's Avatar
lol, Pedders told me mine was rooted about 3 years ago....I too will get it fixed one day ;)
Old 09-11-2005, 12:08 PM   #6
scorpio39
Default Leaking steering rack
My Au 1 commenced weeping 18 months ago. I topped up the reservoir with steering & transmission sealer. No problems since.
scorpio39 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2005, 12:47 PM   #7
Sourbastard
Contributing Member
AUI - AUII between certain periods. Mine is outside of that period.
Old 09-11-2005, 10:10 PM   #8
Mechan1k
Mechan1k's Avatar
I think the recall was actually a stud on the rack that needed welding ... not a replacement rack.
The recall was for early AUIIs and previous ... can't remember the month though.
Old 09-11-2005, 11:08 PM   #9
Stav
Smile
Stav's Avatar
I went into a local ford dealer for the recall and my steering rack leakt all over my stencilling at home.When I took it back they insisted it was not their fault.Got quoted 560 dollars.
If you are in Sydney I highly recommend WESTERN STEERING AT SEVEN HILLS. These guys gave me a great price and service.
Old 12-11-2005, 09:29 PM   #10
Baboon_AU
Baboon_AU's Avatar
when it leaks it just stays on the rack and not in the ground.. i am gtting mine changed in my auII 2001 ute on tuesday.
Its going to cost 570 all up with labour and wheel alignment.
on the same day i am also getting a cooler for my tranny.. its burning the oil too fast and its too hot. thats another 220 fitted.
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 03:55 PM   #11
Autocade
My AU2 went in for the recall work and got rack replaced
I am new here congratulations you have a fantastic forum
I wish I found you sooner
Keep up the great work
Autocade is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 04:30 PM   #12
Nik
we had a lot of dramas with ours leeking ,and turned out it was just the powersteer switch/sensor was stuffed and fluid was leeking out of it.
Old 15-11-2005, 09:14 AM   #13
Sourbastard
Contributing Member
Its a fair amount of cash for what is esentially a broken 45 cent gasket or two.
Old 16-11-2005, 08:38 PM   #14
Baboon_AU
Baboon_AU's Avatar
just got mine fixed and its f**ken great!!! it actually drives in a straight line now and i dont get clunking noises..
as for the transcooler, you can hear the oil getting pumped to it and because the cooler in my radiator wasn't working at all.. i am noticing a lot more power out of it when taking off and just general gear changes... all up it was 770 with Johnnie's GST and i could not be happier!!
Old 18-11-2005, 05:17 PM   #15
diesel17
I have got my power steering rack fixed.
Power steering rack (complete unit) of 2001 au2 that had done 39000 k's $195
Labour to replace steering rack $60
Wheel alignment $35
Transmission fluid $7
GST 10.20
Total $307-20
Compare that to my quote from Ford $852.00 (plus GST) another $85.20
$630.20 I have saved!
I found this site by accident doing a search, this was my first post on here and thank all for their responses. This site is fantastic, I reckon I have just about read every single topic and post on here in the last week!
Thanks Diesel
Old 18-11-2005, 09:15 PM   #16
Baboon_AU
Baboon_AU's Avatar
just a question, do a lot of you guys with AU falcons suffer from this problem???
is it a common problem with the AU?
Old 18-11-2005, 09:42 PM   #17
cArSiK
Its as much a problem with the AU as it is with every other falcon model :togo:
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2005, 09:53 PM   #18
Baboon_AU
Baboon_AU's Avatar
okay... i was just wondering... i guess it is just a ford thing.
Old 19-11-2005, 11:52 AM   #19
ClassicAU
Mine is also leaking, but only onto the rubber boot things. My mechanic told me i can leave it till my next service, but it looks like a few of you guys have gone on a lot longer than that. should i be worried and do something about it before it gets too late? at the moment its only a slow weep i think, no fluid on the ground.
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
