Old 15-12-2005, 10:26 PM   #1
tempest
Default Interior Lighting
Hey, ive noticed on me ef xr, that no lights (meaning central roof light) come on wen the doors are opened at night, is this the way its ment to be, or is sumthing stuffed up, if it is stuffed up, how to go about fixing?
tempest is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 10:32 PM   #2
CruizinEB
can you use it at all like with the switch??
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 10:35 PM   #3
tempest
with the switch, it turns on, but i duno, im just used to a lot of cars it coming on automatically...once ure used to it, u certainly miss it
Old 15-12-2005, 10:49 PM   #4
snypereb
[EBGLT]
snypereb's Avatar
There should be a certain point where the switch moves that the light doesnt come on. But it will when you open the door!
[EBGLT]
Old 16-12-2005, 12:53 AM   #5
John_LS1
um, blown globe????
Old 16-12-2005, 03:52 PM   #6
Martys_EL_V8
Martys_EL_V8's Avatar
well if it works when he turns it on manually id say the globe is fine, check the driver door switch to see if it is getting stuck closed, i had a car that did that.
its a small black pin located just infront of the hinge on the body of the car inside the door jam, if it sticks in when the doors open then push at it or grease it an it should work, that aside a lot of theft recovered cars get wires cut so it may have had that done....
Oh no.. i cant be on my own..
oh god..
ON OWN... ON OWN!!!!
gone are the days when big fords had cigarette lighters in every door
Project FE LTD underway!!
Martys_EL_V8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 05:14 PM   #7
FRDXR6
FRDXR6's Avatar
Could just be the swith position on the light i.e OFF/AUTO/ON (maybe not in that particular order), but make sure you put it on auto and it should work when you open the doors.
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 05:24 PM   #8
xr8svo
Sykmat
xr8svo's Avatar
E-series interior lights dont have on off door switches on them well not that i have scene. I would say that the door switch is playing up probably just needs some lubrication.
xr8svo is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 11:12 PM   #9
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Check the contacts in your door switch's, they are prone to corrosion and breakage.
this will cause your lights not to come on when you open the door, but come on when you use the switch.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2005, 12:32 AM   #10
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
I Changed all mine to LED so it lights up blue at night, also makes it hard to see anything inside the car at night so if some one breakes into my car it makes it harder for them and it looks good,
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
