OLD SKOOL BABY
Just wondering if anyone has any autometer gauges installed in there AU as I am thinjking of getting some as I 'm not real keen on the accuracy of the factory gauges.
PICS WOULD BE GREAT
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP 83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.![]() 1976 XB GS COUPE (waiting to start the rebuild)
You can go Jap Styles and put them on the A-Pillar.
Otherwise, maybe in front of the Gear Knob.
AUIII Falcon Forte, with SIX Appeal |
Or get the Ford Motorsport ones ... I saw them in the Ford Performance mag .... would look much better in the Ford.
I was going to get a couple of Autometer gauges (Volts & Oil Pressure) ... but saw the Ford Motorsport Gauges (has the decals in them as well) .... and they look a hell of a lot better IMHO.
Boost is only option
as for accuracy my Au has a autometer boost guage and it reads 2 psi higher than a chassie dyno and in the cab is a eboost controller and its reads the same as a dyno so when eboost is reading 10 psi the autometter mechanical gauge is reading 12psi
but hey they look sharp!! HotRod
RAW Performance QLD |
My kids think I'm cool
i'm modding the radio surround with a chopped-up second hand unit- I have a single-din Head Unit and am putting in the a/c control surrounds just below it- plastic welding it all together and fibreglass reinforced.
the idea (it's hard to describe) is you will have the three a/c control dials up top, the single din Head unit just below and a repeated set of three dials below the h/u where three 2" gauges can be housed- it will look awesome I reckon- Just waiting to get my car back befor I can take it on. personaly I hate gauges- but I do want to keep a keener eye on the important stuff now i've poured soem coin into the engine.......
2011 FPV GT 335 >My Build Thread< (Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page) BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable... 2018 Ford Ranger RAPTOR 2013 Audi SQ5 |
OLD SKOOL BABY
Sounds good, can't wait to see pics in progress and the end results. :evil3:
I'm guessing you will put 3 gauges, what type?
#7 | |||
the obvious choice would be Ford racing but I prefer a black backgroung and brused silver bezel to blend in better. the gauges will sit more "on" the recesses rateher than house in them- but that would be better for the visibility anyway- and would look sensational
FYI, unless the 5.6 motor was different to the 5.0, the ECT sensor is mounted in the top of the heater pipe where it connects to the inlet manifold on top (just near your coil packs) - the sensor in the resevoir tank is coolant level - not temp.
If you have a single DIN head unit and a spare DIN space, Car Toys in SA sell a steel plate which fits into a single DIN slot and has mounting holes for three gauges in it which are all angled slightly toward the driver - available in black or carbon finish, which I will probably look at getting at some point for mine. |
justa6
![]() Mine's really easy to see, and having it there you can't see it from the outside. a littlt more stealth you know. btw jimte50 and blueprint xr8 i don't know how many blueprint au were made but bloody hell you picked up a winner Last edited by justa6; 08-01-2006 at 09:57 AM. |
#10 | |||
justa6
