Old 09-01-2006, 12:18 PM   #1
ALS008
I'm BOSS
ALS008's Avatar
Location: Where all Fast Fords are From, Northern Melb.
Default Dev 3&5 cam profiles
Whould someone be able to tell me the ballpark cam specs of the dev3 and dev5 cams. Duration @.050, valve lift and LSA
Also can these be bought on there own, or only in there respective kits??
====Past Rides====
'04 BA XR6T 5spd T5: Nizpro Tuned, Valve springs, CIA, Injectors, 256RWKW
'04 BA XR8 4spd BTR:Bluepower Tuned, BPR CAI, Big Boy exhaust, Hi Stall, 4.11s, 248RWKW PB:13.2@105mph
'92 EB Fairmont GHIA 5.0LT 5spd T5:Stock with a cat back exhaust.
'06 BF Fairlane GHIA 230Boss ZF 6spd: BPR CIA, cat back Exhaust.
====Present Ride====
'10 FPV GS Ute ZF 6spd:#108. With all the fruit.
ALS008 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 12:21 PM   #2
Casper
Contributing Member
Casper's Avatar
they are a closely guarded secret. Cams can be purchased individually though
Older, wiser, poorer.
Old 09-01-2006, 12:27 PM   #3
ALS008
I'm BOSS
ALS008's Avatar
Thought someone would say that. Can you tell me if it is wilder than the wade 1521a - which i have noticed a few guys on the forum use??
====Past Rides====
Old 09-01-2006, 12:29 PM   #4
Casper
Contributing Member
Casper's Avatar
The dev 5 is bigger, not sure about the dev3 though.
Old 09-01-2006, 01:55 PM   #5
ALS008
I'm BOSS
ALS008's Avatar
How much for the dev 5 cam on its own? What valve springs does it require?
====Past Rides====
Old 09-01-2006, 08:56 PM   #6
5speedeb
now with 3.73 lsd
cam kit is $920 i think
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 10:55 PM   #7
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Dev5 is bigger than the 1521a, dev3 isnt.
I have run these 3 cams in my car at different stages, the Dev5 Craps all over the 1521a, and the Dev3 is yet to be tuned, but still is a more streetable cam.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 11:43 PM   #8
Walkinshaw
Two > One
Walkinshaw's Avatar
The dev5 has more lift than the 1521a but i highly doubt its duration is as large making it a very streetable cam. If you don't have an aftermarket ECU and your chasing big top end power, Dev5 is the way to go.
