Old 28-01-2006, 11:28 AM   #1
greenant
Default Engine has intermittent miss at 55-65kph
Have just bought 2001 AUll have found that it has a massive miss at 55-65 kph (engine has actually stopped once) while driving it will eventually clear and be ok and for some reason seems to be worse when fuel tank full. Could this be a faulty O2 or MAP sensor. Also can anyone explain what these sensor do and why and where they are situated.
thanks in advance
Old 28-01-2006, 01:56 PM   #2
clontarf_x
chekc filters, lines, and pump. Could be a knackered pump or blocked line/filter.
Also try flushing the tank of its fuel and putting in a nice clean batch. Could also be bad fuel from your favourite servo
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 02:02 PM   #3
Baboon_AU
Baboon_AU's Avatar
o2 sensor is situated on your exhuast manifold or extractors and the MAP sensor is situated around/inside your intake manifold.
correct me if i am wrong but-
-the o2 sensor adjusts the fuel and oxygen mixture from the ECU and the MAP sensor senses the amount of air coming into the engine.
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
