birdy
How much horsepower does a 4l ford produce and what is capable and still be streetable?
birdy ![]() |
turboute
Bit more info than that mate - you probably want to mention a budget.
As for what is capable - Nixpro made a 1200hp XR6T engine - but it cost about 35-40k What is streetable - probably something arount the 350kw mark which would be right on the limit of an Unopened XR6T engine. Stock XT 4L produces 190kW - 250hp - but more like 140kW at the wheels Stock XR6T engine is 270kW - 360hp again more like 210kW at the wheels Anything else you wanted to know? |
turboute
Sorry that XR6T should have been the F6 Engine...
XF 393 3v CHI heads
yea pretty accurate turbs
birdy
Im talking stock 4l 1994 with no radical
birdy ![]() |
I think the 1994 models are about 140KW-160KW or something.
![]() Join Date: Dec 2004
1994 EF
stock was 157kw (I think), XR6 was 164kw.
iRegular crossmember
if they are ED they are 149kw
bugger knows what EF is though
1996 EF XR6 5 spd manual 2 1/2" manta S/S exhaust After market alpine/soundstream stereo 18" tyhpoons superlows waiting to go in.... spoilerless ![]() |
Engines:
4.0L 6 cyl Bore and stroke: 92 x 99 mm Power: 157kW at 4900rpm Torque: 357Nm at 3000rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.3:1 5.0L V8 Bore and stroke: 102 x 76 mm Power: 165kW at 4500rpm Torque: 388Nm at 3000rpm Pushrod overhead valve, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.0:1 5.0L V8 (XR8) Bore and stroke: 102 x 76 mm Power: 170kW at 4500rpm Torque: 398Nm at 3000rpm Pushrod overhead valve, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.0:1 4.0L 6 cyl (XR6) Bore and stroke: 93 x 99 mm Power: 164kW at 5000rpm Torque: 366Nm at 3000rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.3:1 5.0L V8 (XR8) 4.0L 6 cyl (Fairmont Ghia Series II) Bore and stroke: 93 x 99 mm Power: 162kW at 4900rpm Torque: 361Nm at 3000rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.3:1 I just found this for the 1994 through to 1996 EF Falcons. ![]() |
Peoples definition of streetable can be quite different, ive seen a vid of a 7sec pro stock Mustang driving on the street and going through a Maccas drive through, and thats not the best bit, it was also in the snow!
Streetable? Yes. Practical? No
