Old 07-02-2006, 02:26 PM   #1
foxtrot
Blood, sweat & tears
foxtrot's Avatar
Default Getting a Loan.. what to do to car?
Hey fella's im getting a 6 grand loan to get my car on the road asap and do some mods :P
i was thinking
1 grand on exhaust
1 grand on brakes
how much for a rebuild as in all around rebuild .. new pistons, cam, headwork etc
will this blow it out (the price)
basically can anyone tell me what they'd do if they had 6grand budget or around about 6 grand
oh its an 88 EA Ghia 5 speed too
2001 AUII SR 5 Speed
Liquid Silver
Inside:
Momo Gear Knob
Schmick Pioneer Headunit w/ Dolphinvision :
4 Channel Kicker Amp to decent speakers;
Alpine Monoblock to Pioneer Subwoofer;
Tuned to perfect clarity-
Outside:
Pure Sexy Falcon w/18" BA XR8 Factory Option Mags
Clear Side Indicators
Coming soon:
Pedders lowered Sports Ryders all 'round
Extractors/Exhaust/Hi-Flo Cat
foxtrot is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 02:28 PM   #2
foxtrot
foxtrot's Avatar
Open to suggestions.. youi can even suggest brand names and makes of brake systems etc etc
for exhaust i was thinking, pacemaker extractors with 2.5' redback exhaust and hi flow cat
Just someone tell me what to do with this money! i don't want to waste it.. i want as much done as possible
car already has lowered pedders sports suspension and some mags that look damn good for there age (probably really cool 6-7 years ago)
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 02:32 PM   #3
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
Mate, $1000 for a 6cyl exhaust is too much... plenty of companies (redback for one) make a prefab exhaust for E-series for under $500, if i recall correctly. Extractors for I6's aren't expensive either, I think. Plenty around 2nd hand too.
$1000 on brakes is also excessive - all you really need are a set of slotted rotors all around (DBA or RDA, www.discpads.com.au, i think), a decent set of pads (Bendix) and a fluid change. If you go all out, you could get rebuilt or exchange calipers, which aren't all that much either.
Rebuild, I dunno. If it's not smoky or bottom-end-noisy, I'd leave it - a lot of E-series guys get good gains from top-end mods like Tickford heads (or posting and shaving to increase compression) and cam changes. I've not heard of good gains from bottom-end changes, because it's not like you can rev them that much harder, or bump up compression with piston changes.
Even if you were up for a new motor, low k's AU motors are $bugger all from wreckers, and they've got all the good sh#t already in them (head, proper intake etc.)
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 02:39 PM   #4
xe351
xe351's Avatar
i'd talk to jim mock motorsport, they know these engines pretty well and can get some good power out of them.
xe351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 02:41 PM   #5
GreenMachine
Mopar/No Car
I've always been hesitant about a company that sells spark plugs as a performance part, but yes, they do build DAMN fast I6-powered Falcons.
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
Old 07-02-2006, 02:48 PM   #6
ebxr8240
Performance moderator
ebxr8240's Avatar
Buy an AU engine with accessories for $1200.. Just fit DBA slotted rotors and ultimate brake pads [$370]..Fit flywheel to AU engine , new clutch, Bend front support bar forward or cut centre 300mm out and weld same size bar across the front and she'll fit after swapping engine mounts.. Use EA-ED inlet for time being, EA injectors.. Maybe latter 3.45 diff from E.L ...Neoprene suspension bush's and gas shocks, should have nice package..
Depends if you have multipoint engine originally the ecu will run AU with EA distributor...Other than that Stinger or Wolf ecu..
Daily driver GTE FG..
Old 07-02-2006, 03:11 PM   #7
foxtrot
foxtrot's Avatar
yes the cars multipoint,
Is an engine swap a big hassle would it cost much to have someone do it for me.. maybe i should just keep the EA engine it doesnt really blow smoke or have any bottom end noise.. gear changes are a bit rough but might need fluid changed (will have to do this because haven't checked it once)
I said 1 grand on exhaust because its how much my mates AU cost (my mate has a 5spd AU and it hauls ***, he let me take it for a spin).. he has exactly what i said.. pacemakers .. 2.5 exhaust and hi flow cat. cost him a grand
i can get pacemakers for about 400 at the cheapest (new)
exhaust about another 400 (redback, new)
high flow cats around 250 i heard? so thats already over a grand.. so a grand including labour sounded good?
well keep posting ideas fellers .. so i have a few options.. you guys out there certainly know more than me..
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 03:11 PM   #8
foxtrot
foxtrot's Avatar
ps ignore the bad quality of my posts.. its called typing quickly and nervously while shoulder checking every 2 seconds, along with a lot of minimising windows (im at work)
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 03:36 PM   #9
EDXR6T
mate i wouldent b sinking 6g in to an EA:Pthats my opinion
sell the EA then get a good EB_ED then sink ur cash in to that
ull get most of ur money bk from an EB2_ED then an 88 EA mate
plus getting a loan not a good idea ether but hay it's ur choice
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 03:41 PM   #10
foxtrot
foxtrot's Avatar
Nah EA's have character, first of the round shaped fords woo
6g aint much of a loan.. wont be hard to pay off.. my mate got a 20 grand loan for an 87 Celica GT 4.. now thats stupid
20 grand!!!!
and i could beat his car easily with a few mods.. he admits it.. (theres an EA gets around locally with EF engine. cam, exhaust, suspension etc .. keeps up with his turbo' rice burner)
don't plan on getting my money back either.. since when have e-series had much re-sell value..
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 03:55 PM   #11
Jokers Wild
ANYWHERE ANYTIME
Jokers Wild's Avatar
If it wont be hard to pay off then jsut mod as you go and pay cash, you will get more bang for your buck with better mods or fuel to run around with by saving the interest $
Jokers Wild is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 04:02 PM   #12
foxtrot
foxtrot's Avatar
Traineeship ends May . then Im on full wages
Need the loan for now lol
can everyone not tell me not to get a loan and please NOt tell me that an EA isn't worth it..
i want to mod the ea
back the point!!
help me spend money on my EA... EA.. not eb, ed.. EA lol
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 04:21 PM   #13
xbgs351
I suggest you borrow only the amount that it takes to get the car on the road. Borrowing to fund modifications is pure madness. You will never get ahead in life borrowing for things that don't appreciate in value (ie houses, shares, historic cars).
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 04:29 PM   #14
foxtrot
foxtrot's Avatar
could a mod please change the title and what i wrote to "I HAVE 6 GRAND TO SPEND"
take away the loan part
and delete this post
so i get some real feedback
Telling me I wont get anywhere in life because of 6 grand is pretty damn sad.. it's either save up and get mod by mod or do it all at once.. with a loan
big woop
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 04:36 PM   #15
DJM83
Barra Turbo > V8
DJM83's Avatar
Its only healthy advice mate i have nothin againest Ea's never owned 1 but id seriously pay cash you will end up with more but anyway if you want to go that way good luck with all the mods hope to see the finished product
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 04:47 PM   #16
foxtrot
foxtrot's Avatar
yeah i know you're trying to help.. I don't mind.. but I want advice from people who have modded there cars and know whats good..
not just being told its a bad idea lol
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 05:07 PM   #17
XRated
Shoot.
XRated's Avatar
Do what you want with your money. It might be wise to invest it or save it etc, but it's your choice.
For 6k, I'd get an AU engine (600-1200), get some head work (1000) and cam, full exhaust (1000), maybe replace some bushes, upgrade sway bar, diff, and a chip if you can afford it (1000-2000 depending). Other than that, put away 500 or so for maintenance.
20V Turbo
Old 07-02-2006, 05:22 PM   #18
foxtrot
foxtrot's Avatar
but with AU engine what about my EA transmission.. will that fit
I thought being a series 1 EA it had the same gearbox and driveline a 5 speed X-series would have
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 07-02-2006, 05:27 PM   #19
GreenMachine
Mopar/No Car
Yeah, your T5 will fit it (i think?)...
Not wishing to give you advice you haven't asked for, but spending $6k on an EA is akin to lighting cigarettes with $100 notes. Yeah, it'll be a hot EA, but in 2 years you'll be sick of it and sell it for $1500, and you've got nothing to show for it.
Plus, $6k will buy you a bloody good EL Gli/Futura, which will be every bit as fast as your modded EA, and a lot nicer to drive.
Just stuff to think about.
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
Old 07-02-2006, 06:56 PM   #20
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
dude i'll sell it and get a EL fairmont ,then you will wonder why you ever wanted to keep the ea
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 06:58 PM   #21
Kenster
Kenster's Avatar
I say look around if you want restore your EA to former gloire Im sure they are place which sell part cheap or if you know someone who has those part its even more of an advantage
Kenster is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 07:17 PM   #22
LUXO_8
windsor user
AU engine, 5 speed, 3.45 lsd should get your ea going nicely....
and ive got nothing wrong with someone wanting to get a loan to do mods. ive done that for the NC....
its not because i cant afford it, its just im crap at saving, i know what i want, and am getting it.... and will pay it back easily...
Old 07-02-2006, 07:25 PM   #23
Psycho Chicken
Psycho Chicken's Avatar
Not true. He'll have debt for a car he doesn't own!
Old 08-02-2006, 08:04 AM   #24
merlin
merlin's Avatar
Hmmm, firstly (and I know you don't want to hear it), its crazy borrowing money to modify a car. If you don't have it, don't spend it.
Now that is out of the way,
I wonder how much BA XT half cuts go for these days? 182kw, sequential auto in an EA shell :
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop.
Still to go - Holley Sniper EFI with integrated fuel cell.
merlin is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 09:24 AM   #25
Bearman
Moderator Ford Coupe Club
Bearman's Avatar
Hmmm..... For $6K I'd buy a good clean EB or ED XR6. Good performance and handling. Would be an excellent base for mods down the track. Will always retain more value than an EA.
Mitsubishi ASX Auto, White - Daily Commuter
XC Fairmont Coupe, 351 4spd, Graphite Grey - The Antidote
http://www.fordcoupeclub.org
"If you don't know where you're going, any road will take you there" George Harrison 2001.
Bearman is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 10:51 AM   #26
foxtrot
foxtrot's Avatar
THANK YOU
there you go.. crap at saving
I dont think i will regret 6k down the track
1. im 18 and after my traineeship im sales and production manager straight up
2. i live with rents and dont pay board, they make my lunch and cook me dinner lol
3. I love EA's (and EB ED EF EL lol) but EA is what started the reign!
4. It will have a fully siiik fordforums sticker on the back
Liquid Silver
Inside:
Momo Gear Knob
Outside:
Coming soon:
Old 08-02-2006, 12:10 PM   #27
merlin
merlin's Avatar
I googled around for BA half-cuts (still reckon 182kw in an ea would go well) but couldn't get a price, though you can get an S14 200sx half cut for $2200....hmmm SR20DET EA :
Old 08-02-2006, 12:25 PM   #28
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
EF,EL,AU motor and ecu. ($700-$1200)
Pacemakers are $365 on ebay, cat back installed is $300, and hi flow cats are $150ish
DEV4/5, WADE, CROW or ALTED Cam (200-500)
Headwork to match. (valve springs, ports matched, polished) $$$ depends where you go.
Youll then need a chip like a chiptorque, unichip or even a standalone like an MS2 or WOLF3d.. I suggest going 2nd hand with the chip as i cant justify spending $1500 for a unichip when a wolf is just a few hundred extra.
Rising rate fuel regulator($150)
3.45 LSD from a late XR or Fairmont Ghia ($750)
So theres about 4-5 grand... And youll have a good amount of power to go with. (150rwkw+)
But to make it easiest,
EF/EL/AU Motor
DEV3HL Kit
and a chip to go with it...
youll be looking at good numbers then.
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 05:43 PM   #29
Kenster
Kenster's Avatar
THANK YOU
now that the spirit keeping the first orginal E series strong
Old 08-02-2006, 07:29 PM   #30
chevypower
chevypower's Avatar
For $8000 you can get an AU with a warranty from a car yard! Why spend $6000 on a heap of junk (no offence intended) then sell your EA for about $2500 - or get an EL for $6000, and only have $3500 debt
chevypower is offline   Reply With Quote Multi-Quote with this Post
