Old 17-02-2006, 02:00 PM   #1
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Question Rear dood electric window problem.
I only just noticed while cleaning the car today that my rear left window wont wid back up with the button on the door , i can wind it down np - but not up .... Allthough with the drivers front door conrols i can wind it up and down no worries. Any ideas what might be the problem , i cant see it a electric window motor related problem as i can wind it ip and down np with the drivers controls ... any help plz ..thx ?????????
Old 17-02-2006, 03:12 PM   #2
Autocade
I remember reading on a thread that it is probably just a build up of dirt in your switch
I am sure it explained a switch removal & cleaning proceedure and from memory was fairly easy
Had same problem with mine but i gave it a few taps and pushed it a few times and it started working again
I am sure you will find it on here somewhere
Autocade is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2006, 03:39 PM   #3
Stampy
Go but a new switch from ford they are very easy to fit and then you can try and clean out the old one
These switches are a common problem
Old 17-02-2006, 04:02 PM   #4
XR6-VCT-2000
Fantastic Plastic
thanks guys , ill pull out the switch first then and see if that the problem ..thanks .
Old 17-02-2006, 11:25 PM   #5
chief
FTF Club Moderator
chief's Avatar
This is the tutorial written by racecraft that helped me out. Pretty simple.
http://fordforums.com.au/showthread....utorial+window
Albert Einstein:
Fords in the Park 2010
