custom_user_title
If the outside temp is 36 and the inside temp is 40, and I set the climate control to 32 degrees auto, will it cool the car down to 32, or will it produce maximum heat?
Boooostn'
it will give you maximum heat i would suggest! I know my climate control does lol
2012 FPV GS Ute - Kinetic, Supercharged 5.0L, 6spd ZF auto, leather interior - The Boosted Daily! 1979 XD Fairmont Ghia - Silver, 302C V8, Full velour interior, slowly building her up to be a tough cruiser! 2002 Nissan Patrol ST - Desert Gold, 4.8L DOHC 6cyl petrol (Soon to be reequipped with a 5.7L LS1 V8), 5speed auto, lifted, locked, 33's, nature destruction vehicle! |
Lovin the Manual.
same as if its 10degrees outside and u put it on 16degrees it will still do max aircon.
The climate control will look at the data coming from all is sensors and decide what to do. So, if it's 40 outside and lets assume the incar sensor is reading 40 or higher and you have it set to 32, it is going to go into cooling mode until its satisfied the set condition has been met.
This is also assuming its blend door is working properly...
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
Lovin the Manual.
but when u go to its maximum upper ... it goes full hot and if u go to its lowest temp it goes max cold...
Custom User Title
That's the whole point of Climate control....it controls the climate.
You set it to 32C, it does what it has to to get the car down to 32C, it controls the climate. |
That's 3 to 1 BoZZa
custom_user_title
Personally I would think it should cool down the car to 32 whilst in Auto mode, however when I turn auto off and switch to manual I get maximum heat. Is it just me, or is this stupid? Personally I've hated my climate control. I've found it quite stupid. Bring back the dial and levers ha ha.
Last edited by peterwilson_69; 19-02-2006 at 01:44 AM. Reason: said the opposite of what I meant |
eec tweaker
the 32 and 16 settings change to "manual" mode and put out full heat/cool. its there as a failsafe if theres a malfunction with sensors, etc.
set it to 31? which is still ИИИИing hot! |
#10 | |||
In auto mode it is what is known as a PID controller. Proportional Intergral Derivative. It gets a setpoint (SP, in this case the temp you choose), a current value (PV, based on data it receives from the temp, sunload and ambient ensors), and an output (MV, the heater tap, the blend door and the fan speed). If the current value is different than the setpoint it modifies the output to control to the setpoint. If you set it to 32* on a 45* day the climate control will be cooling. This type of control is my field of work, I deal with it daily (among other things).
Adrian EF Fairmont, V8, Pacemaker Headers, hiflow sports cats, redback muffler, DBA Gold rotors, Tickford body styling kit, suspension and rims, heritage green, JVC MP3. XB Coupe, 351C, +30 Speed-Pro hyper pistons, closed chamber heads, BlueRacer cam, Crane lifters, manley pushrods, crane roller rockers, double valve springs, Street Torker manifold, 650 holley squarebore, 4 into 1 headers, twin 2.25" exhaust, 16" thermo, tricked C4, B&M starshifter, LSD 9", discs all round. |
#11 | |||
![]() Join Date: Dec 2004
The climate control is alot smarter than I thought.
I've probably been using mine the wrong way.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
