Old 07-03-2006, 06:12 PM   #1
Deanodriver
Default Two identical EF's, both do different rpm at 100, any ideas?
I've just bought an EF, and driving it home from Vicroads today, I was noticing it was doing about 2000rpm at 100km/h. However, my old man's got a virtually identical car (series 1 Futura, mine's an August 1994, his is a March 1995, I think, both autos), and his does about 1700rpm at the same speed.
I wonder what could be causing it, could I have an aftermarket diff in mine? Did they offer a shorter diff as an option in Futuras?
My first E-series: (*gone* :() 1994 EF Futura
Current Ride: 1993 Ford Telstar GLX, maroon manual sedan, Alpine CD player
Deanodriver is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 06:15 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
was your power/economy switch on or off , same as the other vehicle
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 07-03-2006, 06:15 PM   #3
Deanodriver
Both were set to economy, and both speeds were with the cruise control on exactly 100.
Old 07-03-2006, 06:23 PM   #4
MickyB
Get in the ring!!!
MickyB's Avatar
Same size wheels? Although that shouldn't make much of a difference.
FG MKII XR6T - Tuned by Pit Lane
MickyB is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 06:30 PM   #5
MAD
Petro-sexual
MAD's Avatar
Maybe one is not locking the torque converter, either that or one has a different diff in it to what is expected.
2000rpm is about what our EL monty ghia does at 100kmh from memory. thats with the 3.45 diff.
maybe you got a nice score.
- The Story
Old 07-03-2006, 07:04 PM   #6
DentEd XR8
DentEd XR8's Avatar
Different diff ratios most likely, or the speedo/tacho is out on one of them but that's highly unlikely for that much of a difference tho
Ed
DentEd XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 07:20 PM   #7
Stevo
My power/economy switch makes no difference to cruising rpm.
Deano, try testing the diff rations, id say 1 has a 3.45
Heritage Green EL Ghia
Black AUII XR8 Ute
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 07:21 PM   #8
ilsautomotive
Former E-Series Member
The diff should have a tag on it. There is a small chance that one vehicle has the wrong speedo sender gear but that's a pretty substantial difference between the 2.
Old 07-03-2006, 07:25 PM   #9
cArSiK
tyre size most probably.
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 07:31 PM   #10
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
maby u have more tyre presure in your dads and thiner tyres or it could be the diff
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 08:40 PM   #11
efgiar
rofl copter
efgiar's Avatar
power/econ switch doesnt effect it in 4th gear, has to be diff, stall, or wheels
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 08:43 PM   #12
mr_efxr
Not your average EF Wagon
mr_efxr's Avatar
Tyre size, type of tyres/rims and tyre pressure.
Power by HeadTech Performance Williamstown
The recently SOLD 95 EF Wagon 5spd NA SLEEPER
The Daily cruisers now *95 R33 Skyline GTS-T RB25DET *93 Lexus GS300 2JZ-GTE
Car enthusiasts visit Unique Cars and Parts
mr_efxr is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 08:48 PM   #13
niko
likes falcon's
niko's Avatar
prolly got different diffs.
ie series 1 and series 2
whats take off like?
www.carhubsales.com.au
Old 07-03-2006, 09:06 PM   #14
Deanodriver
The wheels are different (he has stock steelies, mine has 15x7 EB XR alloys, but both have 205/65 tyres on them), it should be about the same at that.
I'm keeping up with the flow of traffic when it's on 100, so I don't know if the speedo is out.
I'll have a look at the diff, it could be different. I think the 3.45 is the most likely, to be honest. I just got the auto serviced (while getting the roadworthy), so I don't know if it's that.
Thanks for that
Old 07-03-2006, 10:22 PM   #15
MAD
Petro-sexual
MAD's Avatar
If your speedo is accurate, then it is definately your diff. If it was the wheels/tyres/pressure it would affect the accuracy of the speedo at the same time.
Also if the tyres were the difference, the tacho would still match up with the speedo reading, even though the speed reading was wrong.
- The Story
Old 07-03-2006, 10:33 PM   #16
Jet-Star
Maybe ones not running right? When my dad got his 95 ghia we noticed that his idled at about 650RPM where as my 95 Futura Idles at about 800RPM....Quick Spray into that little motor/sensor thing ontop of the throttle body and problem solved...Perhaps its a machanical problem your having?
Jet-Star is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 10:44 PM   #17
Southy
different diffs
Southy is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 11:30 PM   #18
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I'd go the different diffs theory too, especially since it is the early EF that is revving higher. They started off with 3.23's across the board but later change back to 3.08 in GLi's (can't remember if in Futura as well) for better economy.
Old 07-03-2006, 11:56 PM   #19
BABOSS
BABOSS's Avatar
Maybe if we posted our RPM@100km/h EF stock diff ranges you will have something else to compare it to.
Mine is the same 2000rpm@100km/h EF NOV '94 Stock diff
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2006, 02:18 AM   #20
efgiar
rofl copter
efgiar's Avatar
mine 2000@100km/h with a 3.45 96 ef ghia series 2
GQ patrol.
thats all
Old 08-03-2006, 02:28 AM   #21
Racecraft
they call me Tibbo
Racecraft's Avatar
My EL 3.08 s/s (without the A/C on) is 1700.. with the A/C on its 1850'ish
Old 08-03-2006, 02:59 AM   #22
EAman
Ea 1990 with ef head
EAman's Avatar
Location: recently relocated from gipsland to newcastle
id say tyre profile or 3.45 diff ratio
EAman is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2006, 08:04 AM   #23
cArSiK
Have you ever had a drag with your dad? If one was faster off the line than the other then they will have the higher revving car at 100.
Old 08-03-2006, 10:13 AM   #24
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
mine is november 94 ef and does 1850 at 100km/h. pretty sure mines a 3.23
however, mine is an LSD and i didnt think ford had an LSD in this ratio.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2006, 11:07 AM   #25
Fairlane
V8 Powaah
Fairlane's Avatar
3.23's came in LSD, on Fairmonts and as an option on GLi's/Futura's. From memory my EL did about 1850/1900 rpm at 100km/h on a 3.23 LSD.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2006, 06:42 PM   #26
Deanodriver
Well, I've checked the diff, and it's a 3.08:1, so that idea is out the window. My dad's taken it for a drive, and he doesn't know why either. He does reckon his accelerates quicker (but it's kind of an unfair comparison, since he's comparing a car with one person in it running on premium to a car with two in it running regular).
Mine does have a rear wing on it (small one), but it wouldn't cause that much drag, would it?
I figured maybe everyone else was speeding, but my speedo was saying I wasn't.
Who knows?
Old 08-03-2006, 06:50 PM   #27
LUXO_8
windsor user
just an idea - one may have torque converter issues. (not locking up)
Old 08-03-2006, 06:55 PM   #28
RavenLS1
i would say diff.
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2006, 06:57 PM   #29
Racecraft
they call me Tibbo
Racecraft's Avatar
are you sure that you are both doing 100? sit side by side with one car @ 100 and see what the other reads.. Just to be sure , a slight difference there, tyre pressures, dragging idler pulleys, A/C compressor bearing etc etc all labour the engine to a certain point
Old 08-03-2006, 07:08 PM   #30
jonbays
TL40 Wagon?
tacho and speedo error is the most likely reason you know. The tacho isn't exactly instrument quality
