Old 22-03-2006, 08:07 PM   #1
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
Default Diff queries...
hey all..
my car has 3.73 single spin, it also has the half moon bracket which bolts up to the tailshaft.. im guessing this is a 25 spliner?
i might be picking up a 3.23 LSD out of a NC Fairlane, not sure if auto or manual..
preferably i'd like to keep my centre on the car and just swap the LSD gear across, and yes the person who will be doing it does know what they are doing..
all i'd like to know, is whether the NC diff would be 25 spline 2 pinion, or 28 spline 4 pinion...
from what i gather if its a 28 spline, i have to change the tailshaft to a longer one?
if this is the case, are the auto tailshafts the same as the manual tailshafts?
help greatly appreciated..
cya,
santo
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 08:18 PM   #2
Damo
auto and manual tailshafts are compatible there is like a couple of mm differance but they both work fine, you won't need a longer one just one with the flange type connection (4 bolts and nuts instead of the 2 saddles and 4 small nuts).
Old 22-03-2006, 08:24 PM   #3
EF_Frmnt
EF_Frmnt's Avatar
As Damo said the tailshafts are the same.. and the centre is the LSD so you would be changing the centre in your car to the LSD. And think its possible to swap from 2 pinion to 4 ask lukey039 the qld club rep he did it to his EA
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 07:39 PM   #4
santoitaliano
BF F6, APV SR3900
even if i decide to completely swap it over, im worried it may be in bad condition... seeming im pulling it apart to change gears over, what do i need to do to reco the diff, especially so the LSD isnt sloppy... cheers,
Santo
Daily:
Bluepower enhanced.
Old 26-03-2006, 07:41 PM   #5
347Stroker
347Stroker's Avatar
NC is 28 spline.
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 11:19 PM   #6
Rollin
Rollin's Avatar
the NC diff should go straight in, if you use an EB or later tailshaft, and you may have to get EB II or later lower control arms, as the EA and i believe EB series one have narrower bushes.
you can bend the mounts on the bottom of the diff in to match the EA arms but obviously thats not preferable.
what diff is your 3.7s originally out of? if they are meant for a X series car then i dont think they will fit the NC diff, but if they are from a R31 or something then they should go straight in, but you will have to get them lapped by a professional, to make sure they last as long as possible.
thats all i can think of off the top of my head...
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2006, 02:13 AM   #7
santoitaliano
BF F6, APV SR3900
i have no idea what they are originally out of but they are already in my 25 spline borgy...
lower control arms are new nolathane.. :S
Santo
Daily:
Bluepower enhanced.
Old 27-03-2006, 02:13 AM   #8
santoitaliano
BF F6, APV SR3900
the 28 spline internals and axles cant be put in a 25 spline housing can they?
Santo
Daily:
Bluepower enhanced.
Old 27-03-2006, 09:41 AM   #9
santoitaliano
BF F6, APV SR3900
i have both complete diffs here now...
i want to use my new lower control arms, so id like to keep the 25 spline housing..
can this be done?
cheers,
santo
Santo
Daily:
Bluepower enhanced.
Old 28-03-2006, 01:49 PM   #10
santoitaliano
BF F6, APV SR3900
OK! all done.. quite a pain in the *** to do. Setting backlash is a ИИИИИ when you have to machine up your own spacers... other problem i had is the crownwheel having different size bolts to that on the 28 spliner... oh and that my left axle that i got with the diff was bent... but thats all being sorted now!
took it for a test run last night, copped a puncture :(
but the LSD works awesome... lovely double black lines...
Santo
Daily:
Bluepower enhanced.
Old 28-03-2006, 07:31 PM   #11
mcflux
mcflux's Avatar
Good to hear mate! Shame about the puncture though...
Old 28-03-2006, 07:43 PM   #12
John_LS1
good ИИИИ, wanna stick 3.9's in my diff :P
Old 29-03-2006, 12:04 AM   #13
santoitaliano
BF F6, APV SR3900
changing the gears is not hard.... setting backlash and ИИИИ it a pain in the ***.. needs to be accurate to 3-5 thou or something..
Santo
Daily:
Bluepower enhanced.
