23-03-2006, 11:02 AM | #1 | ||
TUF-ENUF
Hi I own a Eb 2 that I wanna modify but jus need some help wid a few bits
1st up I had a drifting accident in it n the car veers to the left some ppl say wheel alignment other say tyre rod arm or camber???? i had new front heavy duty struts added, but still veers 2nd up I wanna change the interior and add power windows i jus wanna knw where can i buy power windows in SA and have em fitted at the same time? Also would thermo fans work in a EB 2 and bump the kw's up? lowering, if i wanted it done what is a good reconmended lowering size window tinting can it be done in a EB also if myne is a S pack can i get a cruise control system fitted to it? i would like to knw these things as i bought the EB frm a dodgy dealer n it jus has so many problems : |
23-03-2006, 11:04 AM | #2 | ||
BLOWN 383 CHEV OWNER
thermos can be fitted but dont really think it will bump up the kw's
tinted windows can be fitted to any car you want mate. |
23-03-2006, 11:21 AM | #3 | ||
likes falcon's
apparantly it adds few kw n puts less strain on waterpump as theres less things to be turning
www.carhubsales.com.au |
23-03-2006, 11:22 AM | #4 | |||
Will write that one down for another day. |
23-03-2006, 11:59 AM | #5 | ||
it doesn't add kilowatts...its frees them
23-03-2006, 12:11 PM | #6 | ||
it will give less strain on the engine
but in my opinion thermo's keep the block as kool as the old clutch fan's ther are in some fact's thermo's are a good upgrade like if u have a V8 or a hair dryer hanging of the side:P if u want it lowered it depend's on you'r insurance company some one let u go lowere them 20-40mm then you'r factory ride hight (correct me if im wrong) but i'd go super low King spring's thay give you'r car a nice stance with out alot of scrapidge cruise control can b add'd pritty easy go to you'r local ford wreaker and see wut thay have to say but it's is defanetly posible and look around a wreaker for a fairont/ghia for a set of electric window motor's ther about 100 buck's each i think but you'l need the loom and a fairmont centre console plus the button's pat |
23-03-2006, 12:16 PM | #7 | ||
The 'Stihl' Man
thermos are a great mod..and one that should be done asap..i dont know about autos, but with a T5 it does feel slightly freer.
24-03-2006, 02:46 PM | #8 | ||
Formerly PetesEB
how muh bucks would a themo conversion cost fellas
:gren: Weapon of choice. :gren: EB II, T5, Custom extractors, 2.5'' all the way thru, hardly legal tint, EL XR rims, on its balls, cold air intake + stainless heat shield. Custom boot garnish. |
24-03-2006, 03:32 PM | #9 | ||
hmmmmm
24-03-2006, 04:37 PM | #10 | ||
^^^ Now wtf was the point of that post. Thermo fan conversion shouldn't set you back more than $260, a new set of EF/EL thermo fans is about $220 + some wiring, relays etc.
24-03-2006, 05:04 PM | #11 | ||
Dorifto accident:
Could be one of many parts, but have a look at tie rod end, top strut plate/bearing, wheel alignment. Better still bring it to a few suspension places and ask their opinion. |
24-03-2006, 06:56 PM | #12 | ||
IMO thermo conversions are a waste of time. Anyone got any proof they actually add power on a E-SERIES? Like a dyno printout? The belt still has to turn the water pump so it's going to be doing the exact same thing as before. Only difference is that the clutch fan is not going to be there. It doesn't take any power for the motor to turn the fan normally anyway, the fan only engages it's clutch when the motor gets to a certain temp (too hot)....such as when you sit in traffic. And I don't think your gonna need the extra kw then.
24-03-2006, 08:21 PM | #13 | |||
Heritage Green EL Ghia Black AUII XR8 Ute |
24-03-2006, 09:03 PM | #14 | ||
well said doug, although clutch fans sound like ИИИИ!
24-03-2006, 09:45 PM | #15 | ||
The 'Stihl' Man
yeah sphell...clutch fans are horrible!!!
I dont hvae any evidence, but when I had my EA T5 it seemed to rev a tad easier, its not much, but its definately better. plus as Damo said, clutch fans sound like a WW1 plane
24-03-2006, 11:20 PM | #16 | ||
TUF-ENUF
Agreed hence the reason why i don't want my car sounding like a gusting wind at take off
25-03-2006, 01:00 AM | #17 | ||
First time I gave my XR a rev with thermos installed I nearly hit 6000rpm (aftermarket ECU, so I have a higher rev limit)
Engine feels smoother, quiter at idle, and more top end power. I dont think down low it has made much of a difference.
27-03-2006, 08:49 PM | #18 | ||
eec tweaker
someone dyno it!!
i definately noticed a difference... wether it transates to rwkw who cares, at least it stopped it sounding like ИИИИ. |
27-03-2006, 08:59 PM | #19 | ||
Oops, I slipped....
If the fan clutch is stuffed it will definately make a noticeable difference.
You certainly won't lose power if you fit thermo fans....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
