Old 26-03-2006, 06:52 PM   #1
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
Default watt amp for subs 2
sorry to get the same subject up in a different thread but no-one is answering my last post in the other1. to power 2, 4ohm, 800w peak/250watt rated sub, the frequency response d class appeared the best option at 1ch, 2ohm, 700wrms which means 350wrms to each sub. i then stumbled accross a second amp which is 2ch, 4ohm, 350rms. i know the second is a full range amp but which would be best for my subs?
full range = http://www.jaycar.com.au/productView...=&SUBCATID=595
d class = http://www.jaycar.com.au/productView...=&SUBCATID=595
again sorry for starting another thread but no-one will answer my last post and i didn't get a clear, definate answer.
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 06:58 PM   #2
stiddy
stiddy's Avatar
D-Class amp.
Old 26-03-2006, 08:16 PM   #3
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Are you subs dual voice cone (4ohm plus 4hom) or single voice coil (4Ohm)
Easy way to find out do they have only 1 set of plus and minus plugs to wire to the amp or do they have 2 sets of plus and minus plugs PER SUB?
I have 2 x 2Ohm + 2Ohm Dual Voice Coils 300watt rms 1000watt peak running from 1 Class D Amp 500watt wired at 2ohm (25owatts per sub)
It has awesome bass - my gf can hear my coming home from 2 blocks away.
But i dont think its loud enough.
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 09:04 PM   #4
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
no me either. they r single voice coil.
Old 26-03-2006, 10:48 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
D class mate 350x2 would pull out good sound!!!!
[EBGLT]
Old 26-03-2006, 11:07 PM   #6
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
yeah and the full range amp puts out 380wrms at 4ohm, 2ch (typo in original post). but im only going to be powering the subs. hence my dolema :
Old 27-03-2006, 01:01 AM   #7
stiddy
stiddy's Avatar
If its only for your subs then there is no problems, just go for the D-class.
Old 27-03-2006, 12:50 PM   #8
Sorted
Sorted's Avatar
Yeah D Class 350watts per sub
2 x 4ohm Single Voice Coil wired up at 2ohm
Even know your subs are rated at 250 watt they will take 350 watt as its only short bursts at max power at any one time
Tuned by DYNOMOTIVE
Old 27-03-2006, 08:34 PM   #9
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
all right. awesome guys, been great help. this is the definate clear answer i was looking for... ill let u's know how it all goes in about 3-4 weeks(gotta find the time to go get it then put it in!) ;)
Old 27-03-2006, 10:55 PM   #10
snypereb
[EBGLT]
snypereb's Avatar
D -class is specifically a sub amp aint it?
[EBGLT]
Old 28-03-2006, 01:18 AM   #11
old_mate
Smash the Boost
old_mate's Avatar
pretty much
although i think jaycars new range of digital amps are d class but full range? I dunno. But yea, usually u associate d class amps as being mono blocks
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2006, 10:53 AM   #12
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
The Two D-Class Amps that we(jaycar) sell are both Mono Sub amps.
The 4x100 that your looking at is a good amp, but for your setup id go for the 800wrms D-Class.
I am Currently running a 2x150, with two of our metal cone 10" subs and it goes very hard, but they have 2 x 2Ohm voice coils.
For your single coil 250wrms subs id definately go the 800w.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 08:23 PM   #13
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
sweet kerry. thanks for the info. is it safe to mount the amp on the back of the box? if not, where the hell else could i mount it in my wagon? trying to avoid under the seat.
Old 29-03-2006, 08:36 PM   #14
Poetic Justice
NOT A TOYOTA :/
Poetic Justice's Avatar
Ewwwwwwwwww Jaycar.
06 LandbargeCruiser Sahara
Managed to remain in the v8 fraternity
Poetic Justice is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 08:58 PM   #15
Jet-Star
Originally Posted by blackout
Ewwwwwwwwww Jaycar.
Exactly my thoughts^^...
No problem with mouting your amp to your box, if you don't want it there or under the seat try screwing it to the back of the back seats..
Jet-Star is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 09:03 PM   #16
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
nah i want it on the box but i read in 'in-car' magazine that the vibrations can sometimes cause components within the amp to come loose and it die. just wondering if anyone has had any problems of this kind...wot's wrong with jaycar?
Old 30-03-2006, 08:35 AM   #17
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
There is no problems with mounting the amp on the back of the box, but make sure you have some airflow.
I have my two amps mounted under the floor in my boot, and have put two blower fans under there to give some artificial airflow.
EEEWWWW, Jaycar? WFT? DO you guys even know what you are saying?
Kerry
2008 MA XR5 Mondeo
Old 30-03-2006, 05:43 PM   #18
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
well there will be a bit of a gap between the box and seats due to the measurements of the amp so it should be sufficiant
Old 31-03-2006, 08:21 PM   #19
Sorted
Sorted's Avatar
Thumbs up
I have always mounted my amps on my sub box and never had any problems.
Thats over 10 years with different amps (updating) mounted on a sub box.
These were Soundstream then Coustic then Alpine amps NO PROBLEMS EVER !!
Tuned by DYNOMOTIVE
Old 31-03-2006, 10:11 PM   #20
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
awesome. thats wot im looking 4
