Old 03-04-2006, 02:56 PM   #1
coota
Default changeing oil pump
do i have to take the motor out to change the oil pump :
coota is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 03:00 PM   #2
stiddy
stiddy's Avatar
Nope, but its a ***** of a job..
Sump has to come off..
Old 03-04-2006, 07:32 PM   #3
NZ
NZ's Avatar
And to get the sump off you need to pretty much have the motor out :p
You can also drop the front suspension and k frame if you have a way to hold the motor and body up. probably the easiest way in the long run.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 03-04-2006, 07:42 PM   #4
ebxr8240
Performance moderator
ebxr8240's Avatar
Why ??? If oil pressure is low and over 200.000 I'd replace or overhaul engine...
Good sohc engines can be bought for under $1k even low klr AU engines....
Daily driver GTE FG..
Old 03-04-2006, 08:26 PM   #5
stiddy
stiddy's Avatar
The motor dosent have to come out. It didnt come out when I replaced the one in the AU.
And its a bigger job to get the sump off in an AU then it is in an E series as far as I know.(Ive never pulled the sump off an E series while still in the car) so dont quote me on it 100%.
Honestly, EBXR8240 has come up with a very good option, if your thinking of getting the pump fixed at your local mechanics it will work out more than buying a motor and dropping that in. I got quoted $1200(dodgy mechanic) upto $3000(Ford) for a new pump and labour to do it.
Its also cheaper for an aftermarket high volume pump rather than a genuine Ford pump.
Old 03-04-2006, 08:32 PM   #6
NZ
NZ's Avatar
problem is on the eseries is the k frame is one peice with a bar across the front that makes it impossible to get the sump off. its kinda locked in there. I know what you mean on the AU i've seen how theyre setup and it would be much easier.
Just sucks to own an eseries unfortunatly
Old 03-04-2006, 08:49 PM   #7
gthofan
Gunna girlie-man
gthofan's Avatar
aftermarket high volume pump, i was quoted $160 supplied
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 08:58 PM   #8
EFFalcon
Last warning
EFFalcon's Avatar
if you've never done it then how do you know the engine doesn't have to come out?
i've done it with my car, the engine either has to come out, or the entire kframe dropped.
both involve an engine crane or other lifting equipment to hold the engine.
i'd recommend the kframe dropping idea, thats how i did mine and its fairly straight forward. no worrying about fluid/fuel lines etc, just big bolts that are easy to access.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 03-04-2006, 09:16 PM   #9
John_LS1
i wouldnt bother with a high volume oil pump either. if you want more pressure put a tighter releif valve spring in it.
Old 04-04-2006, 12:45 AM   #10
ebxr8240
ebxr8240's Avatar
Volume is far better than pressure.....
Old 04-04-2006, 02:16 AM   #11
ebs_4l
question ebxr, how can a pump push more volume through the system without a pressure increase??
answer, it cant. by having tighter relief, the pump has to flow a higher volume to be able to increase the system pressure enough to open the spring
example. if 1l of oil will flow through a 5mm hole in one minute at 50psi, how do you make 1.5l of oil flow through that same hole in one minute, WITHOUT a pressure increase?????
ebs_4l is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 04:18 AM   #12
fmc351
let it burn
Thinner oil! :gren:
