BF F6, APV SR3900
silly question... system has been installed for months.. now recently occasionally the subs will cut out for 1-3 seconds. this can occur at high or low volumes it doesnt really matter.. the speakers still continue to funtion normally..
there is a seperate 4 channel amp running the speakers from the monobloc running the subs... anyone?
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
In the family since 1996
check all your earths and conections first, i had a similar thing happen to me. other than that, cant think of anything else without lookin at it myself
Does Steve have a car?
Look at your RCA's, they may be internally broken. Play some music and give the ends going to your amp a wiggle and see if it starts to cut out.
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Santo dont worrie about it it still sounds f*ken mad
likes falcon's
cable issue, check your remote line. mine was rooted and would cut out and do all sorts of stuff
www.carhubsales.com.au |
#6 | |||
I second that. If one of the RCA's is crossing wires internally it will cause this problem. Also just check basic stuff like make sure your earth cable doesn't have a small stray wire touching the remote input etc. Also check nothing is cutting into the speaker wire causing it to earth out. Finally check if the actual RCA connector on the amp itself is not loose or broken in some way. |
Its gone V
i would go with checking your earths has happened to many of cars that i have known about.
BF F6, APV SR3900
rca's ill have to test, maybe remote.. but power and grounds are perfect. those of you that have seen the terminals on a kicker monobloc will understand.
i had that issue with my 4 ch. turns out i didnt crimp the terminal on the ground properly and over bumps and hard take offs it would randomly cut out...it willl just be a wiring problem unless it happens when your staionary as well?
Low and Loud
Santo do you have a multimeter? if so see if it has Continuity check on it.
if so just switch it to that and put one probe on one side of the RCA and the other probe on the other end of the RCA lead. Will tell you if you have a break in it anywhere. As ^^^^ just said, is it when your car is running / driving or just sitting there with the car off?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
BF F6, APV SR3900
lol does not make a difference.. can be sitting in the driveway... low volume as well..
im thinking maybe the internal fan not working properly, intermittently cutting out and then it goes into thermal protection? coz i cant predict it, i cant see if the whole amp is turning off or power is cutting out..
#12 | |||
Low and Loud
check that your power lead and Remote wire are not shorting out ANYWHERE in the car, even under the carpet or where you have fed the cable through the firewall. if that is all ok then I would look at maybe getting it repaired?
BF F6, APV SR3900
warranty
![]() it is way too intermittent... ill have a good look if i get home before nighttime one night this week..
#14 | |||
Low and Loud
Did you install it yourself or did you have it installed Professionally? If you paid to have it installed I wouldnt touch anything and go back asap as if you play around with it your are voiding your warrenty. If you installed it and have problems trying to find it, give me a yell and Ill see if I can come around and have a look
#15 | ||
BF F6, APV SR3900
installed myself.. had a few minutes to look at it and ran an extra remote... maybe that was the prob.. see how it goes..
#16 | ||
Diabolus
my old amp used to cut out if it got too hot
#17 | ||
BF F6, APV SR3900
yea but that would normally be due to being played at loud volumes and you would literally feel the heat...
this happens at low volumes and even when car is first started up...
#18 | ||
Smash the Boost
I think the kicker has a protection light, watch it and see what happens (but i doubt its this)
If your are confident your terminations and earth is good, i'd be suspecting RCA's/HU. Or the amp is cactus
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
