Old 06-04-2006, 06:57 PM   #1
FUZMOBILE
Fuzzy Logic
FUZMOBILE's Avatar
Default difference between xr6 and std injectors???
just wondering if there is any difference in flow between xr6 injectors and standard ef injectors, i know the fuel regulator is 300kpa for xr and 270kpa this leads me to believe that there is no difference between in jectors
FUZMOBILE is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2006, 06:58 PM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
you're right, they are the same
Old 06-04-2006, 07:06 PM   #3
FUZMOBILE
Fuzzy Logic
FUZMOBILE's Avatar
good to know, so does anyone know if the 300kpa fuel regulator, will work fine with standard ecu??? my guess is it does, but does anything need to be upgraded to run the xr fuel regulator optimally?
Old 06-04-2006, 10:04 PM   #4
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
is this the same for ea injectors? are they the same flow rate, so would just changing the reg achieve anything?
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2006, 10:06 PM   #5
EFFalcon
Last warning
EFFalcon's Avatar
EA to EL injectors are all the same.
the only reason you'd want an XR fuel reg is if you needed more fuel.
most of the time our cars run rich anyway.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 06-04-2006, 10:07 PM   #6
InitialD
Low and Loud
InitialD's Avatar
As john just said EA to EL injectors are the same basicly but for some reason companys list EA injectors under a different number :S who knows lol
XR6 and Stock are identical unless you go aftermarket.
Old 07-04-2006, 12:57 AM   #7
ebs_4l
most xr6's make extra power by fitting a std reg, due to them running just a tad rich
ebs_4l is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2006, 07:39 AM   #8
Simmo
White Lightning
Simmo's Avatar
if i were running a fairly decent cam should i keep the 300kpa unit or go down to the 270 as ive heard of gains from dropping the xr6 reg too.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2006, 09:23 PM   #9
ebs_4l
prob go the 270. get both, dyno b4 and after, only a few minutes to swap it over
