Old 13-04-2006, 05:36 PM   #1
Dezza
Parts bin special
Dezza's Avatar
Default Will EL power windows fit an EA?
Well, finally I have the funding to do something about my constantly breaking right rear power window. It's been fixed so many times, I think it's time just to put a whole new motor in it. Now I'm wondering, with the basic door being the same shape, will an EL motor go in an EA? The EA ones were really weak, so I want something a bit stronger.
Old 13-04-2006, 05:37 PM   #2
XRated
Shoot.
XRated's Avatar
Yeah they will.
20V Turbo
Old 13-04-2006, 05:53 PM   #3
Dezza
Parts bin special
Dezza's Avatar
Cool. Is much modification needed, as I know the EL uses thicker glass than the EA?
Old 13-04-2006, 05:54 PM   #4
RavenLS1
ive got el electric windows and i just used my eb glass
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 05:58 PM   #5
Dezza
Parts bin special
Dezza's Avatar
Awesome. Thanks for that. At the moment I have my window duct-taped shut, so it is quite ugly and embarrasing. Not great security either!
Old 13-04-2006, 07:05 PM   #6
LUXO_8
windsor user
the EF/EL regs are all ford sell now, they've got a better motor than EA-ED regs.....presuming to deal with the thicker glass...
Old 13-04-2006, 09:15 PM   #7
Dezza
Parts bin special
Dezza's Avatar
Cool, thanks Wayne. Those EA ones are sh1t.
Old 13-04-2006, 09:22 PM   #8
ilsautomotive
Former E-Series Member
If the window isn't going all the way up, it will be the regulator not the motor which is at fault. My car had a similar problem when I bought it... it would go 95% of the way up and start clicking. The fix cost SFA even though I was paying for labour.
Old 13-04-2006, 09:25 PM   #9
LUXO_8
windsor user
often the cable frey's or snaps, causing it to have heaps of friction, which loads up the motor..... burning it out....
Old 13-04-2006, 09:33 PM   #10
Dezza
Parts bin special
Dezza's Avatar
Nah. The problem is a gear spinning on the shaft. It's done it a number of times. A couple of months ago, a mechanic drilled a hole through the gear, and inserted a pin, but it's obviously snapped. (He actually put 2 pins in - the harder one sheared off after about 10 minutes so he put a softer one in so it wouldn't shear off as easy). It lasted a bit longer, but not long enough. The window stays up fairly well but slips down over time. I can raise and lower the window with my hands. Only solution, replace the unit.
Old 13-04-2006, 10:34 PM   #11
-jjM-
-jjM-'s Avatar
what do they change exacly, just interested
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2006, 12:13 AM   #12
John_LS1
only the ea had the dud design. eb-el had the same regs. obviously the later the model/lower kay car you get them from you would presume has more life left in them.
