Old 26-04-2006, 05:58 PM   #1
BPXR6T
Default CAPA Group Buy
Sorry for the cross post people, but I'm trying to generate as much interest as possible. The kit I'm getting is the Stage 2 EF 4.0. Prices to be posted shortly...
http://www.fordforums.com.au/showthread.php?t=46355
Old 26-04-2006, 06:18 PM   #2
BPXR6T
fyi - for fellow E-Series owners the kit includes...
PowerDyne Kit
1. Supercharger and pulley size
2. Supercharger bracket
3. Supercharger bracket top spacer bush 58mm
4. 1 1/4 x 3/8 Allen bolts spring & flat washer
5. M1.25 x 65mm x 8mm bolts spring & flat washer
6. M1.25 x 90mm x 8mm bolt spring & flat washer
7. M1.5 x 180mm x 10mm bolt spring & flat washer
8. Bottom bolt shim kit
9. Idler pulley mount posts
10. Step bolts idler pulley mounts and pulleys
11. Idler bearing dished washers and sleeves
12. Mount post to bracket bolts 1/2" x 1"
13. Belt 6PK30327
14. Idler pulley shim kit 8 x 12.5mm thin shims
15. Plastic ties
16. Air conditioner protector wrap 500mm (EF only)
17. Intake tube assembly 800mm & rubber angle
18. Air filter mount tube
19. Air filter mount bolt M8 x 20mm nut spring & flat washer
20. K&N filter assembly
21. Joiner tube 90mm x 76mm rubber hose
22. Clamps 84 x 109
23. Aluminium air tube & grommet
24. Special cut 90deg rubber angle
25. Blow off valve
26. Blow off 1" hose 1200mm long
27. FMU number + mount screws
28. FMU fitting 90 deg
29. FMU fitting straight
30. Fuel return hose 350mm x 8mm
31. Fuel clamps
32. Intake clamp 64-89
33. EF only - discharge tube assembly rubber & plastic
34. Stage 3 only - injectors
35. Premium Unleaded & Synthetic Oil Stickers
36. Stage 3 only - fuel pump inline kit
- fuel pump & mounts - tec screws - 100mm high pressure hose
- clamps
37. Stage 3 only - fuel pump relay kit & switch kit
- switch assembly
- 30amp relay & mount screw
- 300mm black wire
- blue spade terminals
- hole terminals
- 4mm red wire 1700mm long
- conduit, small 1600mm long
- 2 core wire 1400mm long
- fusible link wire
38. Hose protector strip 350mm
39. Fuel filter
40. PCV cap and clamp small
41. PCV 90 degree joiner
42. PCV hose 500mm x 10mm
43. PCV tube to intake tube fitting
44. Re-calibrated computer chip plus auto trans control - for autos only
45. Vacuum brass T pieces
46. Vacuum hose 4mm - 1400mm
47. Spark plugs BOSCH- F6DCX/ NGK BCP6ES
Water Injection Kit
1. Water tank and motor
2. Tank mount bracket
3. 2.2 meter plastic delivery hose, nozzle and clamp
4. Tank neck protector strip
5. 25mm x 6mm bolt, nut, spring and flat washers
6. 1 meter of 2 core wire
7. Relay assembly and mount screw
8. Plastic ties
9. Spade terminals – male
10. Hole terminals
11. Fuse link wire
12. Pressure switch and 2 clamps
13. Optional electronic controller
14. No soap water injection (sticker)
15. Low water sensor
16. Low water lamp
17. 2 meter of 2 core wire
18. Spade terminals – female
19. Angle bracket 2 self tapping screws
20. 6mm x 16mm bolt and nut, spring and flat washers
Old 27-04-2006, 04:23 PM   #3
BPXR6T
Still awaiting initial pricing from CAPA. All is looking good so far with 11 solid expressions of interest and a few maybes. If all things work out there will be a number of seriously quick e-series getting around...
Old 27-04-2006, 06:11 PM   #4
HSVETAR
Bring on the lion...
HSVETAR's Avatar
Mmmmmmm....... money....... Dont we all wish we had some........
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD
9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile
XC Falcon project car underway......
HSVETAR is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2006, 06:49 PM   #5
BPXR6T
If supercharging is your thing then this might be a rare opportunity to save a significant amount of money.
I'll see how things work out with this effort but there is scope for future group buys. I personally plan for a cam, shift kit, and intercooler setup. I wouldn't mind seeing what support there is for a bulk buy on each upgrade and seeing how much of a discount I can negotiate on each. Power in numbers.
Supercharging will be out of the budget of some, but maybe you can get in on something in future.
Old 03-05-2006, 04:38 PM   #6
BPXR6T
Hi All,
See the below post for a $730 discount on new CAPA supercharger kits.
Old 04-05-2006, 02:26 PM   #7
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
hey mate...interested...but i think i would need new injectors, fuel pump and cooler. they dont all come in the stage 2 kit. prolly an aftermarket computer would be the way to go aswell. then i would buy. otherwise, i dont believe the kit would work properly.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2006, 02:30 PM   #8
EFFalcon
Last warning
EFFalcon's Avatar
Capa kits are design to work 'AS IS'
you get everything in the kit to make it work fine.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 04-05-2006, 02:52 PM   #9
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
Spot on. If it needs injectors, the kit will come with them. If it doesnt come with them then you dont need them
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
