Was V6corp
Gday,
Just wondering how hard it would be to install a Ford AU XR Tickford Cluster ![]() Cheers |
Ripping it up
easy... if you need one of the blue xr clusters i have one for sale, and i can help you out on the install
Was V6corp
Really? That would be sweet
![]() How much? |
#4 | |||
Oh Yeah!
You should be able to pickup a cluster around $200 second hand, rember you need to change your kms either at vdo or by soldering in your old chip. Wiring it is fairly easy think from memory 3-4 wires need to be moved thats it, much easier if you can get xr loom.
Oh no! Duffman can't breath! Oh, yeah! |
Ripping it up
the one i have is au1, this one only has less than 6000 on the clock
i paid 200 for it, and cant use it (my car is au2) |
Bseries hardcore
isnt au2 and u1 same cluster?
HISTORY: AU series 2 S pack manual BA XR6 mock up [FLINBY] BF MKII XR8, 13.8 @ 107mph BA MKII F6 TYPHOON BA MKII XR6 TURBO BF MKII F6 TYPHOON R-spec, 13.2 @ 109 mph [LTHLF-6] PX Ranger WILDTRAK |
Ripping it up
nope, au1 has red lcd, OPS and other things are different. physically connects up, yes
Was V6corp
So how much would u sell it for?
Ripping it up
200?
its pretty much brand new |
Was V6corp
Decent price, but i dnt get paid for another fortnight (stupid per month pay) So if u can hold out til then, id be happy to buy it.
![]() Cheers |
#12 | ||
Barra Turbo > V8
Also AUI has a black facia AUII/III has a blue facia being a forte im not sure about the oil/volts gauges are they there to be plugged in or do u need to wire them up?
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
Ripping it up
not all au1 has black.
my cluster is au1, and it all plugs up, just the OPS does not work, radiator symbol is where traction should be on the au2, and same with the demistor is abs warning light. speedo, tacho, fuel, and temp all work fine. v6corp, will hold out for you till the end of the week, if i dont hear from you, ill leave it open for the others |
#14 | ||
Was V6corp
Cheers mate, ill get back to you ASAP if i can
#15 | ||
Barra Turbo > V8
Im talkin XR AUI XR clusters are black AUII/III are blue
#16 | ||
Ripping it up
i may have a ts cluster then.. coz mine is au1 and blue
#17 | ||
Its gone V
is the ts one white and or S1?? by any chance.
#18 | ||
Barra Turbo > V8
ts are white and have a T in the centre
#19 | ||
Was V6corp
What ever it is, i want the blue one
#20 | ||
Barra Turbo > V8
So you want an AUII/III XR cluster i have been told these arent interchangable between SI and SII/II
#21 | ||
Sorry to hijack the htread, but can you take the front clear plastic panel off the front of the cluster? (I havent looked yet, but thought I'd ask anyway)...
#22 | |||
#23 | ||
Thanks Howesy, ill give it a go!
#24 | |||
Was V6corp
#25 | |||
then select "workshop" and scroll down and you will see an article that explains step by step the removal of the cluster. Once out you will see how easy it is to get the plastic off. Just be slow and gentle and the botttom of the cluster just wedges in so it sometimes helps to get a thin blunt bladed knife or instrument and slide under the cluster just to break the seal. gentle to a dgree is the key. |
#26 | ||
Was V6corp
Cheers mate
Car: 99 AU I Forte Sedan Colour: Blue Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash Bling Mods: Tinted Windows; JVC CD/DVD HU Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags |
#27 | ||
Ripping it up
i dunno about the specifics, but this one has tickford wings on the speedo side, and is blue in color. looks hot
![]() i can pull model numbers etc off it if need be |
#28 | ||
Was V6corp
Yeah.... i wanna be 100% sure it is series 1, before i buy it.
#29 | ||
Ripping it up
its a S1.
red lcd display. will post you tomorrow with the part number |
#30 | ||
hey guys, then replacing a s2 forte dash with a s2 xr tickford dash what else has to be done...any wires/sensors.....etc
thanx |
