Old 01-06-2006, 03:43 PM   #1
Sweet_EL_
Default What do recomond?? Chasing around 170RWKW
Ok I've got a unichip on the way, thanks to a member here...
So now I'm looking a chasing around the 170rwkw mark but not sure what I should do next... Should I upgrade my cam / if so what cam?? I've been thinking of changing my pacey's 4499 to 4480 comp headers with the ceramic coating, then getting the head ported (to match the headers) and polished.
So what do you guys recomond??
Sweet_EL_ is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 06:59 PM   #2
castek
well i am currently only running pacemaker headers and a sports pipe, and i been told if i chuck a small cam in (not sure on specifics) i'll be bumpin power up to around the 140-150rwkw area. i was told this by a mate i trust and he has done these cars before. so i would definately say cam, and head work. why not look at a package from come racing or someone similar? they'll give you a cam and head work to match.
castek is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 07:08 PM   #3
EDXR6T
170 is some seriouse power out of a 6
you' have to raise the comp for sure and yer huge cam, porting like crazy and all round reco
or just get a low boost snortperformance kit and slap that thing on the side of ur donk
FULLY SICK TURBO ULEH!
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 07:14 PM   #4
BI6TIM
SnortPerformance.com
Well mate my ED does roughly 150rwkw with the standard ecu. Normal old Pacemakers (not comps), 2.5" mandrel bent pipe, K&N air filter and unmodified Tickford head. It does have a cam in it but it's only a baby.
Put a sizable cam and heavier valve springs in it. I don't know what to suggest by way of modifying the head, but with the stuff you've already got in your engine bay and a custom tune you should easily be able to reach your goal in an EL Ghia!
I had an EL Ghia that I put some 'go fast' stuff in, the same cam as is in my car now and it was going sooo fast. But before I got a chance to put it on the dyno or run it down the quarter my wife smashed it to pieces. She ruined the whole drive line :(
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 08:27 PM   #5
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
thats the mark i am aiming for and this is what i have done to get near it (still putting it together).
board and honed out .5mm (20thou)
balanced and sorta blueprinted
block decked 4 thou
crow stage 4 cam 2222543
crow xr6 springs
crow vernier cam gear
head work - ported which flowed 382hp intake, larger exhuast valves, multi angled valve seats, all new stuff in there, head shaved
comp ratio raised to 9.8-10:1
intake manilold modified to flow alot better (early version)
throttle body matched to intake manifold.
normal pacemakers and 2 1/2 mercury system which will be changed to comp pacemakers (better suited to my cam) and 2 1/2 mandrel bent exhuast
haltech computer (later on)
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 08:50 PM   #6
Age182
GMHKLA number plates
Age182's Avatar
mate if that dusnt make more than 170kw theres sumthin rong all dat work should head near or over the 200lw mark good luck tho...
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 08:52 PM   #7
nat_daly
Nat D
nat_daly's Avatar
yeah i was gonna say... if a cam and full exhaust gets you around 150rwkw, let alone a stage 4 cam..
should be pushing 200+rwkw
good luck let us know what u end up getting
old ride#1: ED XR6 5 speed-gone to new home:(
old ride#2:dumped EL fairmont 5l
new ride: Winter white AU2 XR8-manual
nat_daly is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 09:37 PM   #8
mcflux
mcflux's Avatar
200rwkw? Atmo six?
Old 01-06-2006, 10:06 PM   #9
EB Pete
EB Pete's Avatar
Originally Posted by Ghia5L
200rwkw? Atmo six?
i don't know what Atmo stands for, but i have built my car around others on here and i don't think 200+rwkw is possible N/A. this is still a street car (i hope) but i really want to get into the 13s club but i think i'll be really pushing it with the btr sitting behind her.
Old 01-06-2006, 10:18 PM   #10
mcflux
mcflux's Avatar
Got it in one mate, "Atmo" = "N/A" (as in, operates with atmospheric pressure, rather than assisted (forced, boosted) pressure).
I've been checking up on your project too Pete. Good luck with it mate, you've certainly set yourself a difficult goal with the BTR in place.
Cheers,
-Dave-
Old 01-06-2006, 10:33 PM   #11
EB Pete
EB Pete's Avatar
i didn't think anyone was! well then i might actually have to write something in there now.
but on a serious note. i got all the stuff for me car based on what other ppl have on here and they were pushing out between 160-180rwkw. i don't know what mine will do but i'll give ya one tip before you start. work out what you want and waht you want to do and stick by that. i was happy to stick with the btr but found out off here that the T5Z dicks on it, so if your going to do all this, by the sounds of it, go manual.
Old 02-06-2006, 08:47 AM   #12
Walkinshaw
Two > One
Walkinshaw's Avatar
that list WONT get you 200rwkw. Gaurentee it. The cam is tiny and will run out of puff round the 150rwkw mark. 209@50, 500" and 114LSA will NOT run to 200.
Old 02-06-2006, 09:46 AM   #13
F6T
Has V8 envy
F6T's Avatar
Mine is 160.5 rwkt. 96 xh falcon ute (not an xr model).
Unichip, pod filter, port polish, shaved head, extractors, 2.5" exhaust with a stage 2.5 crow cam.
I was after 170rwkt myself but you gotta spend bick bucks to get those last few extra kwt.
I saw a 1997 xh falcon ute in an Aussie Ute magazine a few months back - had the same modifications as mine but he had bored it out and put tougher springs in....that was the only difference and he was getting 172 rwkt.
2005 BA F6 Typhoon 360rwkw
GTX35/82r + 82lb injectors
Nizpro 4" exhaust
Plazmaman 1000hp IC/piping/BOV/plenum
Process West surge tank
Crow springs
TEIN super streets
6/4 brembos
TUNED BY BLUEPOWER RACING
F6T is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 10:14 AM   #14
Kenaz
Kenaz's Avatar
Go to Jim Mock and order a DEV 5. I think they claim around 170rwkW for that package.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 10:17 AM   #15
Walkinshaw
Two > One
Walkinshaw's Avatar
rwmw?
Old 02-06-2006, 10:21 AM   #16
Kenaz
Kenaz's Avatar
Originally Posted by Walkinshaw
rwmw?
Sorry that's what I meant.
02 BA XR6 T U R B O
Old 02-06-2006, 03:51 PM   #17
Sweet_EL_
I was planing on keeping the BTR if it held up to all, but I would love a T5Z. I miss my T5 from my EA. How much is a T5Z? Are they ez to find?? Or can I rebuild a T5 into a T5Z??
FULLY SICK TURBO ULEH! .
I don't want to go silly with head work, so if don't get to the mark 170 I wont be upset. but if I want more power I have an old snort kit from my old EA some here might remember it (StarkEA)... Which it should fit on it...
What a good cam that wont change the idel too much that it'll be noticed??
Old 02-06-2006, 06:11 PM   #18
BI6TIM
You can get the t5Z from Mal Wood Automotive in Warwick, they charge about $2200 for it. Don't know if that's fitted but it's not like he'll be fitting it for you seeing as you don't live anywhere near Warwick.
The BTR will take the power if you spend a couple of bucks on it. Call MV Automatics in Melbourne and ask them about it.
Good luck with the power search man and let me know how that Unichip goes.
Old 02-06-2006, 06:18 PM   #19
FRDXR6
FRDXR6's Avatar
For 13's you would definantly need a T5/T5z and 3.7 or 3.9 LSD.
I dont think anyone has ever got to 200rwkw with an n/a I6 yet alone one that was driveable on the street.
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 06:26 PM   #20
EB Pete
EB Pete's Avatar
will it run to 170rwkw? i thought it was quite big compared to others out there?
Old 02-06-2006, 06:58 PM   #21
MADED-6
MADED.6
MADED-6's Avatar
yeah not even the jmm red eb gets 200rwkw. theyre making 185rwkw i think it is.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 10:15 PM   #22
The Goodz
E-Series Firemaker
The Goodz's Avatar
The cam I've got in mine is a 650" lift with 10.5:1 comp, extractors, 2.75" exhaust, ported/polished head, 4L AU bottom end, ported inlet manifold and enlarged throttle body with a Wolf 3D and AU injectors, and I'm doing 160rwkw on a poor tune, with potentional for 175-180rwkw with a good tune and a CAI and thermos (still running clutch fan). No way known you'll get anywhere above 150-160rwkw with the setup you're suggesting.
Alex
Automotive photography, fine art landscapes, portraiture
Photo retouching and restoration
The Goodz is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 11:25 PM   #23
opto
Alex
How the hell are you running a 650" lift with that compression of 10.5:1.
Even if you fly cut your pistons, the valves would be bouncing off your piston tops and your rockers would be twisted metal.
opto is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 11:26 PM   #24
The Goodz
E-Series Firemaker
The Goodz's Avatar
Well it would appear not!
Alex
Old 03-06-2006, 11:16 AM   #25
Walkinshaw
Two > One
Walkinshaw's Avatar
Go arround and ask what lift speedway racers run in their 4.0's. I'd be supprised if they said under 600"
PV clearence isnt just related to lift, it's related to cam timing and ramp rates more so that lift.
Old 03-06-2006, 11:17 AM   #26
Walkinshaw
Two > One
Walkinshaw's Avatar
I run a 217@50 with 524thou lift, and I'ts designated as a torque/towing cam.
Change to a Crow 2250 ;)
Old 03-06-2006, 06:45 PM   #27
EB Pete
EB Pete's Avatar
well there ya go! dammit. well i can't go the 2250 cause it's for the EL-AU motor. the only next crow cam i can go is the race cam. what other cams out there are good enough to get me to 170rwkw?
Old 03-06-2006, 10:13 PM   #28
mcflux
mcflux's Avatar
Increasing rocker ratio should get a bit more lift out of whatever cam you run... But I think that messing with the 3.9/4.0 rocker ratios isn't a good idea (unless someone here can confirm otherwise)
Old 04-06-2006, 01:02 AM   #29
eb2fairmont
its 2:1 standard anyway.
eb2fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 01:21 AM   #30
mcflux
mcflux's Avatar
jeebuz! That's insane... so they'd bump up the lift a cam gives a fair whack eh...
And here I am with 1.7s...
