Old 02-06-2006, 11:51 AM   #1
OzJavelin
OzJavelin's Avatar
Default Not happy Jan!
After my big dummy-spit about startup knock on my AUII 5.0L I changed the oil to Castrol 15W-40 (XR8-spec) and it quietened it down a fair bit. Still a bit of cold-start slap (120,000km). However I drove it again last night (my wife usually drives it) and I noticed that you can just hear a bit of a slap/knock when hot. Not happy. I was expecting that the old 5.0 would last a good 200,000km or more without major dramas. While it's not enough to warrant immediate inspection, I think I'll be squirrelling away pennies for a rebuild in the future ..
Rod.
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 04:28 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
give any engine curry all the time and they don't last long , especially the bottom end bearings in the v8's imo . Bummer about the knocking , but i bet you have thrashed it enough times so far to warrant it though probably .
:eclipsee_
Old 02-06-2006, 09:00 PM   #3
JC
JC's Avatar
A V8 is made to give curry all day every day - torque band is flat between around 2000 and 4000, and those revs should not be doing damage to the car at all. For example, mine is an ex NSW cop car, so was probably given a hiding, and the way I drive it is not too far different either. 150,000km and still going strong (touch wood).
Ford Performance Club ACT
Old 02-06-2006, 10:33 PM   #4
XR6-VCT-2000
Fantastic Plastic
lol , if you truelly give it curry heaps all the time it wont last long before it needs a rebuild , that goes for any engine , worked or not.
quote of the day "A V8 is made to give curry all day every day" ! ...lol
:eclipsee_
Old 02-06-2006, 10:37 PM   #5
bodes-sh
well id rather give a v8 curry all day than give an import 4cyl rice all day lol
Old 02-06-2006, 10:40 PM   #6
XR6-VCT-2000
Fantastic Plastic
Sheez yeah ! , me 2 , a decent 6 or an 8 , anything other than a 4 cylinder / jap mobile .
:eclipsee_
Old 02-06-2006, 10:49 PM   #7
xd5.8l
xd5.8l's Avatar
Same here 140,000. I get lifter rapping noise on start up (lifters a tad worn) for about 1 minute and piston slapping noise for up to 30 seconds. Still delivered the goods at CALDER with descent MPH. Shes going out to pasture now and with thicker oil can't see why it shouldn't last at least 200,000 km.
xd5.8l is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 11:05 PM   #8
XR6-VCT-2000
Fantastic Plastic
To be honest with ya , imo weather its a bit of slap in the pistons or worn bottom end bearings , bit of knocking yeah , but it aint gonna kill the engine or really effect your times noticably unless your running like a 10sec 1/4 mile car ! . I wouldn't even let it bother you at all unless it gets really loud/bad and starts to effect the performance too , which is very unlikelly - something else would probably snap and break before the bottom end fully gave out anyways , then worry about it then while doing a rebuild .
:eclipsee_
Old 02-06-2006, 11:36 PM   #9
bodes-sh
i know its not what you want to hear but i just read this on a website
Quote from carpoint:
The imported V8 was subject to lapses in quality, exacerbated by stockpiling after Windsor production ended. Check for rattly lifters, dropped valves and bore distortion and premature oil-burning. In later XR8 and T-series models, the V8 also suffered chronic fuel starvation under hard acceleration for which there now should be a fix.
Old 02-06-2006, 11:47 PM   #10
xd5.8l
xd5.8l's Avatar
That mostly applies to the 185 kw series 1 XR8 and base model 175kw motor because they were just bolted into the cars unlike AU 2+3 tickies.
Old 02-06-2006, 11:54 PM   #11
BJ
Rod.
Boy and i thought our NC Fairlane had problem with 530,475km on the clock. All we get first thing in the morning is a little lifter noise.
BJ is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2006, 08:58 AM   #12
OzJavelin
OzJavelin's Avatar
Yep .. and that's what mine is .. 175kw in XL ute. BTW: It never gets rev'd over 4500rpm .. the worst it gets is towing stuff (eg. cars on trailers). I'm still happy with the ute and it probably makes economic sense to jus rebuild the shortblock (at least) when the time requires. Just disappointed that I've got a 1969 AMC V8s in my Javelin that's done 130,000miles unopened and other than the rear main seal leak still goes fine .. and an '01 engine which makes worse noises ..
Old 03-06-2006, 09:46 AM   #13
howesy
howesy's Avatar
Mine has never run quiet since new and every ford dealer I saw said thats the way they are its the overlap in the cam and the ticking is the valve operation resonating through the extractors (they sure get the excuses good). But funny enough I built plenty of clevelands that ran quiet.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2006, 04:16 PM   #14
Blanchy4
The Dok's Big Bro.
I had an AU 1 XLS 5ltr Ute from Brand New and drove it hard all the time, including long distance runs and loaded up the rear with heavy redgum wood in winter during the 5 years i had it. 260,000 kilometres and never touched the engine from day 1 with regular servicing. It is still around my area as a tradey ute and he is happy with it.
I have a BA XR6 Ute now and it has only 70,000 ks and i hate it. More rattles than a babies cot.
I still have the flanged dual exhaust of that Ute with dual MOROSO POLISHED S/S Mufflers,which i am selling if interested for $300.Designed to come out the rear on each corner.
ing_sm
Blanchy4 is offline   Reply With Quote Multi-Quote with this Post
