Old 03-06-2006, 02:37 PM   #1
howesy
howesy's Avatar
Default Part# does not add up
Anyone struck unusual part numbers? My T3 engine has the 82mm throttle body which ford and the data base say should be 9E926 A but mine is 9E927 AB with an aftermarket engraved number 28 after the batch details. Ford says cant be right but it is. anyone struck these anomolies before or did I just ask the wrong people at ford.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2006, 02:57 PM   #2
rayner22
rayner22's Avatar
um aftermarket throttle body maybe?? It mightn't be genuine Ford
rayner22 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2006, 03:49 PM   #3
howesy
howesy's Avatar
bought the car new. 2002 pursuit 250
Old 03-06-2006, 03:50 PM   #4
Laminge
Cuban... nothing like it
May be old stock from a TE S1 or S2
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2006, 04:04 PM   #5
howesy
howesy's Avatar
They weren't 82mm on the 200kw and 220kw of series one and two. 70mm on both.
Old 03-06-2006, 04:26 PM   #6
Laminge
/me goes back to head butting wall!
Old 03-06-2006, 04:31 PM   #7
howesy
howesy's Avatar
Dont do it too much you'll end up like me. Old and slow
Old 03-06-2006, 04:58 PM   #8
12
Silhouette AU1 TS50.
12's Avatar
200kw has 65mm TB, and 220kw has 70mm (Tickford winged) TB.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2006, 11:03 AM   #9
Papa Smurf
Papa Smurf's Avatar
Partt numbers on parts are not always the right ones. The numbers that are engraved in parts are ENGINEERING numbers and NOT always numbers that Spare Parts uses. That's more likely the problem here? Don't forget, majority of parts for V8's come from America. They do NOT always use the SAME numbers we do here in OZ.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2006, 03:46 PM   #10
howesy
howesy's Avatar
Finally found someone at ford that struck it before and he said simply that the stamped part number is not aleays an exact match to the data base. It is the australian made for tickford item and is around the sixteen hundred mark to buy. Hope the sucker doesn't stuff up then.
